Question about Car Audio & Video
When powered on protection light comes on
I have a visonik 2318 amplifier and it just stoped working and now the protection light comes on. I have put a new amp in its place and it works fine i have a sony x-plod 600 amp and it was hitting fine then one day i noticed it wasnt hitting i got out and the power protection light was red and the sub isnt hitting when i turn the truck off then back on it hits for a little bit but when i turn the stereo past 15 it cuts off
  • sub freak Mar 11, 2009
    it has to be grounded right tho i have neon lights hooked to the ground and they work just fine??? if it wasnt grounded right wouldnt it affect the lights to?
Or the ohms I had a 4 ohm volfvenhad 800 watt amp and I tryed to run at 2 ohms and had the same problem and swiching speakers fixec iy
Posted on May 31, 2011
    Problem Solver:
  • 6 Answers
Ya i would say its not grounded right
Posted on Mar 03, 2009
I think my amp is in protection mode how do i trouble shoot
disconnect speaker,turn gain down to about 10%.repower amp check and see if protection light comes on.if it does recheck power,remote,ground,if it doesent go into protection then kill power and rewire speakers
Apr 30, 2009 | Visonik V2208 Car Audio Amplifier
Visonik V1201A 1-Channel AB Amplifier Problem
in that case check all the wiring to make sure it is correct
Apr 15, 2009 | Visonik V1201A Car Audio Amplifier
Visonik amp problem... amp goes in and out of protection
Check for intermittent shorts on the speaker leads.
Turn down the volume control on your head unit while operating the amp, you could be over driving the amp.
Remove Speaker leads and reset the amplifier. IF the protection LED still comes on amplifier is faulty.
Below is the link to put in a help request with the manufacture for repair.
http://www.visonikcaraudio.com/category.jhtm?cid=27
Mar 25, 2009 | Visonik V408XT 250W x 2 Car Amp Car Audio...
Protection light on Visionik V204XT
What happens if you have the positive 12v wire from the battery connected?
Nov 16, 2008 | Visonik V204XT Car Audio Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Protection usually means that there is a short some where. If it is inside the amp or external I couldn't tell you. You could check the fuse to make sure that isn't blown. I had a Memphis amp that blew both fuses and the protection light came on. I swapped out the fuses and worked fine, still works. If you have a multimeter set it to OHMs and check the resistance between the power terminals. It should be very high. If these things don't work then there is most likely something wrong with the amp or your power termination. I wasn't able to find a lot of information on this amp but if it has screw type terminals, did you use terminals. If you just put the wires in the terminals make sure there wasn't loose strands touching. I hope you can get this one.
-Andrew Hawkins
Mar 27, 2008 | Car Audio & Video
VB101PK REV 13, AMP WITH SUBWOOFERS
was the amp hooked directly to the box? You probably rattled the power connections from the circuit board like I did on a PT 800 watt amp.but check amp fuses first.
Sep 15, 2007 | Visonik V117SX Car Audio Amplifier
Visonik amps turn on into protection mode(where green not red for three days)...switched over the wires to some sony amps and they dont even turn the hell on
the fuze could be blown on the amp or the speakers are to much power for the amp at full power so try to turn the amp to half and not to turn the speakers all the way up,.
Jan 24, 2007 | Eclipse (XA1000) Car Audio Amplifier
Car Audio & Video Logo
252 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
