Question about E-Machines eMachines Desktop PC
Cd burner can i put my dell cd burner in my emachine? it didnt come with a burner, but it has a place for one/
  • 463 Answers
As long as the CD-Burner will fit in there, and the same interface (IDE,SATA, etc.) is available on the E-Machine, it should work fine.
Posted on Mar 02, 2009
  • 408 Answers
Yes.  Just make sure you set the burner to cable select and make sure it is on its own cable on secondary IDE on the motherboard.
Need a dual layer dvd burner for desktop emachines ET1831-03
What is special about this machine or its DVD drive?
Check the power supply and data connectors. That is probably all you need to know. Check Newegg.com
e.g.
Home Computer Hardware CD DVD Blu Ray Burners Media CD DVD Burners...
or
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007589%20600003509%20600003655&IsNodeId=1&srchInDesc=dual-layer&name=12X&ActiveSearchResult=True
The DVD+R DL designation is possibly what you want.
Jan 18, 2014 | eMachines ehines et1831-03 pentium...
Can i take abunner from one dell computer out and put a bunner from a nother dell computer
Hello, there is no problem on switching similar burners if the destination computer has a free interface connector for the type of connector of the replacement burner since they are plug and play. The form factor is the only thing that could cause problems after that.
Jan 11, 2011 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Pls help me... my dvd rom have coins inside.i didnt know.i put cd and then it cant open and i cant take out the cd aswell. my laptop is dell studio 1435... pls help me...
Look at the cover near the cd slot - it should still have the hole. You mention coins inside - kids? It seems probable that the cd was installed with power on, but you will still have the hole - it's small so that a paper clip will just fit into it. Since you have the coins probably still in there, I would disconnect power, remove the cover and pull the cd driver from the tower case. More than likely the cd and cdrom drive will be damaged beyond repair, but if you remove the drive from the computer you'd be able to shake the coins out of it and also to be sure the coins aren't going to short out *********** board. If you can do that then you might as well reinstall everything and put it back together, then power it up to check it. Who knows you might get lucky...
Sep 23, 2010 | Dell (JP-03G005-26401-16R-H324)...
Acer emachines D525 having dvd-rw DS8A3S plays
setting in your DVD burner utility
look for options or advanced settings on the utility that burns the DVD or CD's i e nero or roxio etc.
Usually you can format a DVD CD burner to make it playable on all devices
ok?
Jun 11, 2010 | Acer Computers & Internet
Ntldr is missing
If you have XP then try holding down the F11 key after reboot. This will start the recovery console. I have actually 3 emachines desktops. I feel your pain. If you need more help let me know.
Mar 21, 2010 | E-Machines W3107 (RBW3107) PC Desktop
Wrong side dvd place in
Unless you let it stay there for a long time, then I think it could cause something weird. But from my experience, I accidentally placed the wrong side and immediately removed it. As far as I know, it didnt cause any trouble for my dvd-rom.
Jul 25, 2009 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Dell Dimension 4700 CD/DVD drive not reading
The CD Drive has probably gone bad. You will have to buy a replacement drive. I recommend newegg.com. The price will be about 30$ for a DVD burner. If you want just a DVD player or CD Burner then it will be even cheaper. Dell provides a very easy to read step by step guide with pictures on replacing your drive here:
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Good Luck!
Hope this helped!
Apr 22, 2008 | Dell Dimension 4700 PC Desktop
Cd burner
1) On the bottom of the laptops you are able to pull out the devices. Do so and make sure no pins are broken or anything, place it back in and retry.
2) Check your device manager to see if your dvd burner is installed. Make sure there are no "!"
3) Put a dvd or cd in the drive and listen to see if it spins.
Nov 12, 2007 | Dell INSPIRON 6000 CENTRINO...
CD burner
Sounds like an issue with the drive. Is your computer still under warranty? If so then I would call dell and get it replaced. If not, then I would replace it myself.
Jan 12, 2007 | Dell (1Y414) DVD+RW Burner
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
