Question about Kenmore 73952 Gas Dryer
My kenmore dryer wet sensor light not come on
I think the sonsor system not working. please tell me how to fixing this because when my machine stop the cloth still kind of wet. i have ot dry one more time . I need help please thank you
Change thermistor
Posted on Mar 03, 2009
I have a Kenmore Elite HE3 model 11094834200 it heats up for about 5 minutes and than stops heating. I replaced the thermistor thinking that was the problem but it wasn't. If I try re starting t
Number 34 is the sensor strips located on the rear bulkhead inside the dryer. Clean them thoroughly with Windex or 409. Dryer sheets build a wax buffer on them sensors that moisture cannot penetrate. If no wetness is detected the control shuts her down thinking them clothes is did. Either that or you forgot to reconnect the sensor wire when puttin her back together Kimosabe.
Jul 10, 2012 | Kenmore Elite HE4 Electric Dryer
Gas dryer will not heat up and will not stop going unless I turn timer to off.
Check the exhaust line. If it is clogged with lint the dryer will not heat hence your machine will stay running if the sensor indicates your clothes are wet. when you check the clogg start from the dryer all the way to termination point.
May 22, 2010 | Kenmore Dryers
I OWN A KENMORE ELITE OASIS HE TOP LOAD WASHER AND I AM HAVING PROBLEMS WITH RUNNING A FULL CYCLE WITHOUT HAVING TO ADJUST THE LOAD A F 51 CODE APPEARS AND THE MACHINE STOPS. PLEASE TELL ME WHAT I NEED TO...
F51 MEANS BAD READING ON THE RPS SENSOR. COUPLE OF THINGS YOU NEED TO CHECK. IT'S A LITTLE COMPLCATED. IF YOU ARE A LITTLE MECHANICALLY INCLINE, I CAN WALK YOU THRU IT WITH WITH NO PROBLEM
BOYNISMO@YAHOO.COM 714-334-1998
Dec 06, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Hi, I have a Kenmore gas dryer that shows the symptoms above -no heat, but everything is operational-. I have replaced the thermal fuse, and both thermostats. It did work for a few minutes, but then it...
Really? You want me to pay you to tell me how to fix it, but you want me to TELL YOU how I fixed it for free? Some scam you're running. Please remove my e-mail address from your system.
Jun 11, 2009 | Kenmore 72062 Gas Dryer
Kenmore 11070702990 Gas Dryer - Timer does not work
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Aquarius
i have the same problem if you find out please let me know...... think may need a new program for machine would be cheaper to buy new one all together
Jul 22, 2008 | Hotpoint Aquarius WD640 Front Load...
No Heat
have same problem with my dryer. Check your sensor out,
Jun 14, 2008 | Kenmore 75944 Gas Dryer
Not starting 1 yr old kenmore elite smartheat quietpak9 HE4
SEE VIDEO
http://www.youtube.com/watch?v=tq3k22cqjR8
Control panel moisture 9/10 times.... or check the fuse under the lower front panel ($12 sears)
Nov 28, 2006 | Kenmore Elite HE4 Electric Dryer
Kenmore 73952 Gas Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
