Question about Toshiba Gigabeat MEG-F20S MP3 Player
Firmware for Toshiba GigaBeat MEGF 20 HDD Audio Player
No System found on Harddisk
  • bobafett_h May 07, 2009
    No Systsm Found on HDD. Have tried installing the version 2 software that came with it and it's formatting utility and also the version 3 one, but neither one has fixed the issue.
    Regular files transfer to and from it no problem like a regular USB storage device. I'm using Vista, so perhaps the software is not compatible, although I have used gigabeat room on Vista before to transfer music to it with no problems in the past.
ThaMp3Doctor
  • 8596 Answers
SOURCE: TOSHIBA GIGBEAT MEG-F20S MP3 - ERROR NO SYSTEM FOUND ON HDD
When formatting occurred a key system folder was erased - Toshiba no longer maintains the replacement software -sorry
Posted on Jun 25, 2008
SOURCE: toshiba gigabeat F40
Because bootloader found ,must copy again GBSYTEM
Posted on Apr 27, 2008
SOURCE: meu202 gigabeat 2GB with windows xp SP2 and WMP 11
mine wont even turn on....
Posted on May 18, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Driver files for Toshiba Gigabeat MES30VW
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
MediaMan85
  • 163 Answers
SOURCE: no system found on hdd
Sounds like a HDD crash, try booting with a startup or recovery disk to see if you data is still there. If so, BACK UP IMMEDIATLY. Then you will have to reinstall your Operating System. MM85
Posted on Jul 22, 2008
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba gigabeat F20 i 'm getting a system error 000000001, can anyone help and tell me what i need to do???
It's been 12 years since I got my Gigabeat F20 and now I was able to restore it, finally... I found all the original system folders inside and old backup HDD. If someone needs them, please let me know :D
Jun 15, 2010 | Toshiba Gigabeat MEG-F20K (20 GB) MP3...
System error 00200060 NO SYSTEM FOUND ON HDD ona Toshiba MEGF40. I tried firmware upgrade, reformatting but not working hellp me
Okay, here's what you need to do. I'm assuming at some point yours like mine was formatted under windows. This is bad for them lol. Locate your copy of gigabeat room, and install it. This comes with a extra program in the start menu titled formatting utility for gigabeat. Format with this program, and then look under program files/toshiba/gigabeatroom/GBsystem. Copy GBsystem to the gigabeat, then turn the battery off with the switch on the bottom for thirty seconds. That should do it.
IMPORTANT NOTE!!!!!!!!!!!
This can only be done with a computer running USB 1.0. My newer computers could not "see" the gigabeat properly. I used an old machine with outdated USB to get mine to work again :) you can also check for aftermarket firmware called Rock Box, just installed that one mine, no more converting music to *.sat, it'll take straight mp3s now just like it should :) uploaded 20 gigs to it in less than half an hour :) beats the hell out of waiting ten hours for 8 gigs lol!
Jun 14, 2010 | Toshiba Gigabeat F40 40 GB MP3 Player
Could I please have more instructions on how to restore firmware data as I am still getting same results. "NO SYSTEM FOUND ON HDD" 00200060
Just install your software that came with your Gigabeat. After installation please run the following program. Start/Programs/Toshiba Gigabeat Room/Formatting Utility for Gigabeat. This will place all the files back in the hard drive. Please do not format this unit from My computer to the drive letter. You end up deleting the system and boot files. if that does not help try this in your software you right click on your gigabeat room and open it up and find gbsytem folder drag and drop into your gigabeat on your my computer screen. and then check out.try it couple of times.many times this does work for first time directly. -------- you can also try contacting topshiba service center click the link directly http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp ---------- try downloading the firmware again and installing it in your device click this link directly for firmware http://www.megaupload.com/?d=MO4S7T6I ----- This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Oct 22, 2009 | Toshiba Gigabeat MEG-F20K (20 GB) MP3...
System error 10 please help
The solution for a Code 10 is to uninstall and reinstall the software. Unplug the mp3 player from the computer. Uninstall the Toshiba software. Reinstall a clean version of the software from Toshiba's website. Then replug the player. If you continue to have a problem, and are running Windows Vista, upgrade the firmware: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/askIris.jsp
You need to download the MEGF series v.3 update
-Tha Mp3 Doctor
Jan 07, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
Cannot Instal CD for Toshiba Gigabeat F40 on Windows Vista
Download the MEGF Series Update 3 from Toshiba's website
Nov 10, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
System error
I Fixed!!... LO ARREGLé!!!!... Mi objetivo era ponerlo a funcionar de cualquier forma y LO HICE!!, igual que todos, lo formateé y me comenzó a dar el error del sistema en el HDD, prácticamente tenía un DD portátil. Ahora lo tengo funcionando con el software libre “ROCKBOX” el cual tiene solamente ventajas en comparación al limitado firmware del GIGABEAT y es abrumadoramente más completo y, por ejemplo, no se necesita nada ni similar al “GIGABEAT ROOM” para cargarle música al reproductor pues es tan simple ahora como copiar y pegar (inclusive desde el WINDOWS VISTA) . Los pasos exactos no los podría decir pues fue puro ensayo y error pero es simple, deben buscar el “ROCKBOX” para GIGABEAT serie F en la misma página de ellos (totalmente gratuito) y también buscar la carpeta “GBSYSTEM” pero en Internet, desgraciadamente no puedo dar la dirección exacta pues no la guardé pero no tardé mucho y OJO, no sirve la carpeta “GBSYSTEM” que viene con el cd del reproductor, esa está vacía o con unos archivos ocultos, la que se baja de la red trae al menos dos archivos del tipo “FWIMG” (es más, estoy casi seguro que en la página de “ROCKBOX” explican como conseguirlo de forma simple), la pegan en el reproductor conectándolo como USB. Teniendo todo ello listo, van instalándolo según las indicaciones del PDF que está en la página de “ROCKBOX”… Mucha suerte!!!! Y apreciaría que me contaran si tuvieron el mismo éxito que yo a josedanielcr@gmail.com.
Oct 30, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat MEGF-20
Your battery has a low voltage.
You need to rejuvenate it.
Jul 08, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
TOSHIBA Gigabeat 10
easy. just reload the firmware with the supplied cd. mexico
Jan 06, 2007 | Toshiba Gigabeat MEG-F10K MP3 Player
Toshiba Gigabeat MEG-F20S MP3 Player Logo
1,023 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
