Question about Loewe Articos 55 55" Rear Projection Television
Noisy color wheel
Can someone send me the disassemby and cleaning instructions for the color wheel
  • Loewe Master
  • 5,138 Answers
You cannot clean color wheel you must replace it Call Encompass Parts 1-800-638-3328 or Look up their website they should have a listing on your TV and Parts avaible, also replace it as soon as possible so you do not have bigger problems and Do Not Play set with color wheel going bad if it Breaks apart you will have Major Nightmare with the damage it can cause!
Posted on Nov 14, 2009
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a Samsung DLP HLR5067 modeel tv, recently we have replaced the lamp, ballast and color wheel. The color is ok but when we watch dark (color)movies the black and browns look shadowed and irdescent. ...
You probhably have the wrong color wheel. There are several different ones and its imparitive that you replace it with the correct one. If you search here theres someone else that had the same issue and when they put thier old noisy color wheel back in the problem went away.
Nov 15, 2010 | Televison & Video
I just bought the HD50LPW42 from someone he said it needs a color wheel. When I turn the TV on the green light comes on but I don't get any picture. What is a color wheel and is it needed to just watch the...
Most DLP TVs have a color wheel. This allows the TV to be manufactured with a single chip to control the color for each spot on the screen and a white light source. As the wheel rotates, the desired color light gets transmitted to the screen. This happens so fast that most people do not see the screen refreshing each color.
Here is one source for a color wheel for your TV: http://chaparral.shopjimmy.com/catalog/product/view/id/200632/s/rca-color-wheel-212184/ . This is a part reclaimed from a TV that was damaged in shipping so it was only used during factory testing. The part number is RCA 212184.
Usually the symptom of a failing color wheel is the TV being very noisy on startup (a whining sound) followed by it shutting down. Although other problems can be involved - for example a power problem going into the assembly with the wheel (there is a motor that turns the wheel).
I hope this helps.
Sep 29, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
I need instruction to dissasembly the logitech harmony 550
It´s very simple to disassemby it, you need to force with a little screwdriver as shown in these images. 20b34c1.jpgf933c6b.jpg79788d2.jpg0aa041e.jpg64cc0aa.jpgd49680d.jpg8ec64e0.jpgb5f5e97.jpg46665e8.jpg
Dec 23, 2009 | Logitech Harmony 550 Remote Control
Sony DCR-TRV330 The tape door will not close
just remove mechanisum and clean all strip and solder boar conectors leg
Jul 08, 2009 | Video Cameras
Ballast or color wheel next?
The color wheel will normally spin-up even for a brief moment when the set is powered up. I have not seen a color wheel go out with a lamp. I have seen a ballast go bad with a lamp. I would replace the ballast first. You did not state wheather the color wheel was noisy or not. On the Samsung DLP, the color wheel is normally very noisy before it is gone. I hope this will help you.
Apr 29, 2009 | Televison & Video
Color wheel sound
FWIW
had a 46H84 given to me after "engine failure diagnosed" by Tech and $800 + estimate
Removed the engine and found the color wheel was very dirty and the shaft was not spinning well- cotton swab and denatured alcohol did the trick-
then cleaned the lens which was also dirty and while I was at it cleaned the mirror and backside of screen
Turned it on and WALLA- new set - the fan is a little noisy yet but liveable.
Total investment? 3-4 hours, 10-15 cotton swabs and a little alcohol- for the set on a rainy Sunday afternoon.
Just took a little common sense - the service manual is available online also for about $8 shows basic teardown but does not get into engine teardown which was very basic. My guess is a majority of engine failures after 4-5 years are simply in need of a good cleaning in reality
Dec 15, 2008 | Toshiba 62HM95 62" HDTV
Color wheel
Please send your email address to aavltd@btconnect.com and I will send you the instructions.
Aug 01, 2008 | Loewe Articos 55 55" Rear Projection...
Color Wheel
if it's the color wheal call me 592 6422713
Jul 23, 2008 | Toshiba 52HM95 52" HDTV Projection...
Loewe Articos 55 55" Rear Projection Television Logo
169 people viewed this question
Top Loewe Televison & Video Experts
Jerry Umali
Grantec 2000
Level 1 Expert
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
