Question about Jenn-Air JCD2389G Side by Side Refrigerator
Grinding noise on right side of refrig ceiling
The right side of the ceiling (to the right of the water filter) of my 5 year old side-by-side (model jcd2389ges) is making an occasional grinding noise.
Any idea what mechanism is there, what problem may be, whether this grinding sound could lead to greater damage if left unresolved?
Jenn-Air provided no tech assist on phone.
Thanks,
Jeffrey
202.465.9654
  • jeffreyhw Mar 05, 2009
    now the chattering is gone but refrig is not cooling at all. freezer is very cold (5 below fahr) & not responding to setting. i unplugged for 5 min.s then replugged - no change. could a broken a.d.c. cause these problems? if so, where would i find a replacement? i'm no techie, so how to "easily" replace?
    thanks a bunch! jeffrey
  • deeptiks May 11, 2010
    Hi, this post is very useful but I cannot get the plastic cover out. The cover is held in place with two clips which are not budging when Itry to pull the cover using the finger holes. How to I dismount the cover from these clips - any tricks ?
    President:
  • Jenn-Air Master
  • 2,651 Answers
Sounds like a relay in oyour adc(adaptive defrost control) is getting stuck causing the "chattering noise" you can replace the control easily for about $50.. the top cover pulld straight out and a few screrws hold the top panel up, to reveal the control box in upper right corner. turn off power before attempting lotsa wiresup there
Posted on Mar 04, 2009
  • Ron Coons
    Ron Coons Mar 05, 2009
    yes the control allows the machine to "defrost" so its possible thqat afaulty control would stop machine from defrosting, build up so much ice as to "choke off" the refig side, yet the freezer work seemingly fine.. the part number you ll need is 61005988.. and not bad to change..if you can reomveth eupper plastic housing from the refrig section( youll feel finger holes across the back 2 corners to "pull the top cover down, form there youll need to remove 2 1/4in. screws from withre side ofcontrol knobs, one screws under the filter housing, and 2 phillips screws next to the lightbuld assemblies, the top plate will fallaway, revealing the control in the right rear section. it will unplug, and replug the new board( 2 1/4in screws may secure form underneath)
Where is the water filter for an Amana refrigerator model sqd26ve located?
your water filter is in the upper right hand corner of the fresh food (refrig.) compartment above the upper most shelf in the ceiling
GENE
Aug 27, 2011 | Amana Refrigerators
Where is the water filter located in back?
On your refrigerator filter is in the ceiling of the refrig. section above the top shelf in the upper right corner
The part number for the filter is ukf8001 its available at your local appliance parts store,Sears,
Lowe's or HomeDepot. Just take in the old one to match it up.
Gene
Aug 15, 2011 | Maytag MZD2669KE Side by Side Refrigerator
Does kenmore refrigerater model 596.57542791 have a water filter ?
In a search of the parts breakdown for your model# their is NO listing for a filter. If it did have one it would be in the refrig, compartment on the right side ceiling above the top most rack/shelf
Aug 13, 2011 | Kenmore Refrigerators
Good morning, Dear Professional, It does not have
Morning David,
More likely than not a 12 year old refrig. is not going to have a built in filter,they only have been in fairly recent refrigs. under say 7 years old.
NOw the probable trouble with the icemaker is in this case going to be poor water pressure into the refrig. You can disconnect the water line from the house plumbing on the back of the ref. and check for pressure of incoming water, if it just trickles thats the problem and nothing wrong with the refrigerator, if the pressure is good the water valve the incoming water connects to needs to be replaced,
IF water enters slowly the most likely trouble is the supply usesa clamp type valve that clamps over a cold water pipe,if that is the case that peircing type clamp on valve needs to be replaced.
Gene
Aug 04, 2011 | Frigidaire FRS3R5EMB Side by Side...
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
Where is the water filter in the bottom freezer amana energy saver model refrigerator; and how do you change it?
according to the model number that you gave this particular unit does not have a filter built into it. most amana bottom freezers ahve the filter located in the refrig section on the ceiling. there is a thumb latch you push in and a cover lets down to expose the filter. then turn 1/4 turn counterlokwise to remove. if this doesnt sound right post back wiht a complete model number from the refrig and I will take another look for you. thanks for using FixYa peyton
Feb 17, 2009 | Amana ABB1927DE Bottom Freezer...
Serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water filter
are you looking for a replacement filter for your refrig or looking to locate its whereabouts in refrig???? 11 years ago its possible, sorry very probable that a water filter did not come equipped with refrigs.if so it would be in top right corner mounted on ceiling insider refrig.
Mar 11, 2008 | GE Profile TPX24PBDCC Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
335 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
