Stereo reciever takes several seconds to power up
Lafayette model LR- 2020A stereo reciever: when powering up,        the lamps that illuminate the reciever flutter in brightness and eventually reach full brightness   when unit is on and working.
  • samsavas Apr 07, 2009
    I have a Lafayette LR3030A and I just bought it today and when I turned it on....same prob. lights flicker a few secs and then goes on bright. I'm hoping I can use this suggestion here on how to fix. Thanks much all.
  • 4,234 Answers
The power switch is arcing internally and needs to be replaced. This is a common problem with some older receivers. Sometimes the switch can be opened and the contacts burnished.
Dan
Posted on Mar 02, 2009
What is the color code for the radio ? we are changing the radio and need the wire codeing for the factory radio
For 2001 Buick Century Car Radio Stereo Audio Wiring Diagram...
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope helps (remember to rate this answer).
Dec 30, 2010 | 2001 Buick Century
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
I please need a kenwood kvt 516 wiring diagram to hook up my stereo i dont know what each color is. like left fron speaker etc. please help
battery yellow
accessory red
ground black
power antenna blue
amp turn blue/white
illumination orange
dimmer orange/white
RF + gray
RF - gray/black
LF + white
LF - white/black
RR + violet
RR - violet/black
LR + green
LR - green/black
Sep 27, 2010 | Kenwood Car Audio & Video
Changing the factory stereo need the color coded wiring diagram
you can buy,well we can,adaptor plugs to connect to the h/unit and to the wiring loom plug.normally its yellow=constant power 12v +,red=ignition feed 12v+,[some are other way round]black=earth,blue=power antennae,grey/greyblack,RF speaker,white/whiteblack,LH speaker,Purple/purple black,RR speaker andgreen/green black LR,,orange =illumination dash lights.Those are our standard colour codings,we get in New Zealand.
Jul 01, 2010 | 2001 Ford Mustang
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Toyota tacoma 2007 stereo wiring Colors for the following wires: Power-ignition Ground
Radio 12v blue/yellow + radio harness
Radio Ground brown - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- pink - purple +,- radio harness or amplifier
RF Speaker +/- lt. green - blue +,- radio harness or amplifier
LR Speaker +/- black - yellow +,- radio harness or amplifier
RR Speaker +/- red - white +,- radio harness or amplifier
Notes: If equipped, the amplifier is on the passenger side rear cabin wall.
Sep 13, 2009 | 2007 Toyota Tacoma
Color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Dec 28, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
My RM 2652 when dry camping it uses the 2 batteries overnight ?
OPERATING MODES
AUTO MODE
Press the AUTO/MANUAL mode selector button (2) to the DOWN position. The AUTO mode indicator lamp
(A) will illuminate.
When operating in the AUTO mode, the AUTO mode indicator lamp (A) will illuminate. The control system
will automatically select between AC and GAS operation with AC having priority over GAS. If the control
system is operating on AC energy and it then becomes unavailable, the system will automatically switch to
GAS. As soon as AC becomes available again the control will switch back to AC operation.
If 120 volts AC is not available, the control system will automatically switch to GAS operation. Within 45
seconds the burner should be ignited and operating normally. If unsuccessful, the CHECK indicator lamp (B)
will illuminate.
To restart an ignition attempt with the CHECK lamp illuminated or to clear (turn off) the CHECK lamp, press
the main power ON/OFF button to the OFF and then to the ON position. The control system will attempt a
new 45 second ignition sequence.
On the initial refrigerator start-up on gas (120 volts AC is not available), it may take longer than 45 seconds
to allow air to be purged from the gas line. If the refrigerator has not been used for a long time or the LP tanks
have just been refilled, air may be trapped in the supply lines. To purge the air from the lines may require
resetting the main power ON/OFF button (1) three of four times. If repeated attempts fail to start the LP gas
operation, check to make sure that the LP gas supply tanks are not empty and all manual shutoff valves in
the lines are open.
NOTE: DO NOT continue to reset GAS operation if the CHECK indicator lamp continues to be illuminated
after 3 or 4 tries.
Nov 18, 2008 | Dometic RM2652 Refrigerator
89 people viewed this question
 Grubhead
Grubhead
