Question about Intel Motherboard
How do I find my memory module on the computer?
Can I open up the computer and see what type of memory module it is? Or are there different types which look the same?
I have an intel celeron processor 564 mhz, 128 mb ram. My daughter is using it for school work, etc.
I bought a memory module ddr2, 512mb, pc5300/4200 (667/533 mhz)
do you think I can install it? The computer was given to her but it doesn't have a manual. If I can find one online I would but I haven't been able to.
  • 1 more comment
  • Angela Guevara Mar 04, 2009
    I found out they don't look alike. it's a kvrpc100/128-cr module. but the one I bought is a 512b ddr2, 667 mhz.
    I'll use it in another computer because I don't think they're compatible.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    We need to know the make and model of the motherboard or desktop computer first before we can determine which type of memory it uses and to give you direction on how to install it.
    regards
  • Shakeel Muradali
    Shakeel Muradali May 11, 2010
    the type of memory your computer uses is most likely an SD RAM or a DDR1 type memory,
    IS this a laptop or a desktop computer?
    Problem Solver:
  • 27 Answers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
ahgqqq-3
Posted on Aug 28, 2009
  • 447 Answers
Here's the thing, there are a lot of different flavors of ram (with differences in voltages). If you can post the type of motherboard you have I can easily look up which mods your machine can support.
You can download this utility if you want to try to identify your hardware without opening up the box...
Posted on Mar 02, 2009
  • John Elliott
    John Elliott Mar 04, 2009
    For ultimate compatibility (based on the chip number you provided) your machine uses 168 pin PC100 SDRAM (it probably supports PC133 also but I'm going by the existing ram mod). Your best bet is to upgrade it with two 256mb mods (for a total of 512mb) as I can't be sure if your machine will support 512mb mods. Again, if you can post the motherboard and/or make and model of the PC I could tell you exactly what it supports.
    Many brick and mortar vendors don't carry these mods (or if they do they're on the expensive side).
    These chips can be picked up on ebay used for about $10 each. New ones run about $20 (w/shipping).
    As for the DDR2 you purchased - if you plan to use it in another machine you'll want to verify the voltage of the chips and check the memory upgrade specs for the board you're planning on putting it into to make sure it's compatible.
    Novelist:
  • 121 Answers
You can go here and they will tell you what type of memory is compatible with your system. Just enter in the information and they will show you all types and sizes that are available with that system.
Armymason
  • Garrett Murray
    Garrett Murray Mar 04, 2009
    Its simple to install, like changing the air filter on a car. Open the case remove the memory line up knotches with slots on board and push down only applying a little pressure, dont want to go nuts and bend the board, but it will take a little force to lock into place. Make sure the tabs on the sides are locked in and close up the case. Verify in the sytem properites to see if the memory is accepted, by right clicking on my computer and clicking properities. Also make sure the computer is unplugged and you ground yourself before attempting to do this.
    Armymason
  • Intel Master
  • 3,051 Answers
Hi there
yes you can open up the case and see the memory you have jsut make sure that u turn off the computer first . i recomend that if you are going to update your memory i would first remove one of the sticks of memory and compare it to the one that u have and make sure they match i.e. how many slots are on the sticks length ect ect and if it does match yes go ahead and install it. once u istall it and turn on the computer you will get a memory change notice. ok best regards mike
  • Michael Thomas
    Michael Thomas Mar 04, 2009
    Hi there again.
    hey i sent intel a e-mail about your processot and what you have and what you are trying to do.. this morning i just recieved a e-mail from intel and they have stated and guaranteed that the information that you have gaven me with your processor type ect ect will work as long as the memory stick has the same slot (s) they are recomending that you go to 2- 256 modules for the best performance for your machine but yes the stick that you have would be compatable for your system as long as the stick has tyhe same slots
Power light amber with code 3 and 4
Looks like Memory Issue,
Memory modules are detected, but a memory power failure has occurred.
You can try as follows :
  • If two or more memory modules are installed, remove the modules, then reinstall one module and restart the computer. If the computer starts normally, continue to install additional memory modules (one at a time) until you have identified a faulty module or reinstalled all modules without error. If only one memory module is installed, try moving it to a different DIMM connector and restart the computer.
  • If available, install verified working memory of the same type into your computer.
Let me know
Thanks
Feb 18, 2014 | Dell OptiPlex 780 PC Desktop
Tip
How to Choose Memory (RAM) for Your Computer
You need memory for your computer. But how should you choose the right kind? Whether you're upgrading your computer or building a new one, learn now.
Step 1 If you bought your computer from a manufacturer, use a search engine or go to the manufacturer's site to find the specs on your model. The max RAM found in the specs is likely the max RAM the whole system supports. To find the largest size module the system supports, divide the max supported RAM by the number of slots. Also listed in the specs should be the max speed supported and DDR type (listed as DDR, DDR2, or DDR3). Alternatively, instead of max speed and DDR type, the specs may list something like PC# ####, where the "#" is some number. This is just a different way of representing speed and DDR type, and works equally well in finding the right RAM. If you know the largest supported module, max supported speed, and DDR type, skip to the Tips and Warnings section.
  • Step 2
    If you're building a new computer, follow the above step, except search for motherboard model specs rather than computer model specs. If you don't know the model, look for it printed on the board.
  • Step 3
    If you couldn't find your computer's specs, the info wasn't detailed enough, or you have a custom-built computer, go to http://www.gtopala.com/siw-download.html (also in the resources below) and download the freeware SIW. Install and run it. On the left side, under the "Hardware" section, select "Memory."
  • Step 4
    The "Memory Summary" section on the right side shows the maximum amount of memory that can be installed in the system (listed as "Maximum Capacity"), and below that is the number of memory slots (listed as "Memory Slots"). The "Device Locator" sections tell whether or not memory is installed in that slot. To get the largest size module the motherboard supports, divide the "Maximum Capacity" by "Memory Slots." To get the speed and type, look under the "Device Locator" section, for the listing "Memory Type." Write down the PC#-#### part, where "#" is some number. Also for the listing "Speed," write down the value in parenthesis. For example, in 333 MHz (DDR2 667), write down only the (DDR2 667). You now have the largest supported module, RAM speed, and DDR type. You can use either the PC#-#### or the speed and type when searching for RAM.
  • Step 5
  • In Step 4, you found a supported RAM speed, but it may not be the fastest supported. Just to make sure, look to the left side in SIW. Under the "Hardware" section, select "Motherboard." Using this info, go to the manufacturer's site or do a web search, and see if you can find what maximum RAM speed the motherboard supports.
  • Step 6
    If you're building a new computer and need to buy RAM, look up the specs on your motherboard to find out what kind of memory it supports.
  • Step 7
    The RAM you buy should be no larger than the max supported module size, and should match the type and speed supported by the motherboard.
    Open source site for computer pc error fixing software site is on http://digitalpowering.blogspot.com
  • on Jan 08, 2010 | Computers & Internet
    Can't seem to get nextech memory stick to fit into IBM computer
    Hello wswarts547,
    It's possible that the module of memory you have is not the right type for the motherboard you are trying to put it in.
    There are different types of memory. (DDR, DDR2, DDR3, and SO-DIMM is for Laptops)
    Each has a not or two in different places that prevent installing the wrong type into the wrong socket. Check the specifications of the motherboard and make sure you have the correct module type.
    Hope this helps!
    Jun 28, 2011 | Computers & Internet
    How to identify the memory modules?
    ovenkar50036, this is Lenovo Support > ThinkCentre M58e desktop computer > User Manuals,
    http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=444460&brandind=11&doccategoryind=0&modelind=0&doctypeind=8&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=49980&machineind=0
    In the list I would like you to click on -
    Hardware Maintenance Manual (HMM) (March 2010) - ThinkCentre M58e
    Now click on the blue file name - 53v6397.pdf
    This is a Service Manual. It is also a PDF file.
    The computer you are using now has Adobe Reader on it, which uses PDF files.
    (Although I would recommend upgrading to Adobe Reader 9, if that computer does not have this newest version. Protects against viruses trying to come through a PDF file, and works better than the older versions)
    [ I'm using Adobe Reader 9.3.4. It took a split second for the first page to pop up. Took 3 minutes for the file to fully download. Suggest you let the file fully download before looking through it. I'm using a medium speed DSL connection ]
    Computer on a table, unplugged from power. When you open the computer case, immediately TOUCH the metal frame of the open computer case, to relieve your body of Static electricity.
    To open the computer case:
    Go to Page 91 for Types 7258, 7260, 7268, 7270, 7280, 7296, 7298, 7304, 7307, 7413, 7491, and 7408.
    (Type is next to the Model Number on the back of the computer)
    Processor to the top, the Ram Memory modules are to the right.
    Page 90 shows an illustration of the motherboard.
    Page 105 shows replacing Ram Memory modules.
    This illustration also shows the location of the Ram Memory modules,
    http://www-307.ibm.com/pc/support/site.wss/MIGR-71963.html
    ( Number 3)
    Go to Page 133 for Types 7259, 7267, 7269, 7279, 7290, 7297, 7303, 7306, 7408, 7487, 7506, and 7514.
    As you can see the Front Panel, (Cover), is tilted forward for some models. This brings the optical drive up to allow access to the Ram Memory.
    Page 135 shows replacing Ram Memory modules.
    Page 140 deals with replacing the motherboard. It also has a crude illustration of the motherboard.
    The Ram Memory modules are shown to the left. The Processor is under a Heatsink, which is shown on the right.
    (The Heatsink is illustrated as a tall rectangular block, with vertical lines on the side towards you)
    This illustration also shows where the Ram Memory slots, that the Ram Memory modules are installed in,
    http://www-307.ibm.com/pc/support/site.wss/MIGR-71926.html
    This is what the ram memory modules look like,
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1558873&CatId=2366
    Post in a Comment of what Type your Lenovo ThinkCentre M58e is, and I'll tell you;
    1) What type of DDR2 Sdram ram memory it uses.
    2) What the Maximum Total Amount of ram memory is.
    3) What the Maximum Amount for EACH ram memory slot is.
    Oct 31, 2010 | Lenovo ThinkCentre M58e Desktop Intel...
    With 512MB RAM in slot1, laptop is working fine, but when I tried to install other 512 ram in slot 2, there were no display and numlock and caplock led start blinking. Both RAM are originally shipped with...
    umm .. Are both RAM memory modules the same type? You can fit different types of RAM to a computer but they may not be compatible together. Check that both modules are the same.
    Other than that, it sounds as if the problem may be slot 2. This would suggest that either the RAM isn't being correctly engaged or the slot is faulty.
    Switch off the computer. Put a memory module into slot 2 to see if the computer works. Try it with both memory modules using slot 2. If neither memory module works in slot 2 this indicates a fault - motherboard probably.
    If one memory module works in slot 2 - but not the other module - this tends to indicate a mismatch between the RAM modules and they are not compatible together.
    Aug 14, 2010 | Dell Inspiron 6400 Notebook
    Addrammemory
    If your desktop is a Dell Dimension 2400 then this is the technical specs for the RAM.
    Memory
    Architecture
    DDR SDRAM
    Memory connectors
    two
    Memory capacities
    128-, 256-, or 512-MB
    Minimum memory
    128 MB shared DDR SDRAM
    NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
    Maximum memory
    2 GB
    Memory type
    PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC)
    The RAM modules are held in place with clips on the ends of the RAM modules. Push each clip down and away from the RAM modules and the RAM module will lift up.
    To install the RAM modules, the RAM modules have a notch and can only be installed one way. Place the RAM module in the memory slot and push down until the locking clips swing up. You may need to push the clips into the sides of the memory modules to lock and secure the memory modules.
    The price of the RAM depends upon the size of the RAM you want to install. I suggest a minimum of 1Gb of RAM and the maximum to can install is 2Gb of RAM.
    Check the prices of RAM on the Internet and in the computer stores.
    May 22, 2010 | Dell Dimension 2400 PC Desktop
    Can I put different types of RAM on a motherboard?
    Not different types per se, but you may be able to put different speeds.
    Type would be like DDR Sdram2_bing.gif, or DDR2 Sdram for example.
    Speed is a slang term for Frequency Rate. What frequency rate does the ram memory2_bing.gif module (Stick) operate at.
    Example: DDR2 Sdram that has a frequency rate of 667MHz. (PC2-5300) MHz stands for MegaHertz.
    Mega = approximately 1 Million. Hertz stands for Cycles per Second.
    The above ram memory module operates at 667 Million Cycles per Second.
    If you install two ram modules that have a different frequency rate, all the ram memory installed will operate at the slower frequency rate.
    (Provided the computer will support more than just one frequency rate)
    Have a computer in mind, or is this just a generic question? A what if?
    Reply to your recent comment:
    If this is in relation to two different manufactures of your ram memory, it shouldn't be a problem.
    Where you may get into trouble in this area, is if one ram memory module (Stick) is generic, or low budget, and one ram memory module is a high performance gamer ram memory.
    Without knowing the exact manufacturer of your computer, plus the Model name of it, and also knowing the information you have about your ram memory 'sticks', the following information is just generic, or general information.
    High performance ram memory may use a higher voltage. Not always, but a good portion of the time.
    High performance ram may also use a faster set of ram timings.
    It may also have high density DRAM chips, and the chip configuration may be setup differently.
    (The black rectangular modules you see on the side of a ram memory 'stick', are DRAM chips)
    To explain so far;
    SDR Sdram was the typical ram memory for years after SIMM ram memory.
    SDR stands for Single Data rate.
    Commonly just referred to as Sdram, but in actuality that is erroneous.
    (Sdram stands for Synchronous Dynamic Random Access Memory)
    Then came DDR Sdram.
    Double Data Rate Sdram.
    Then DDR2 SDram.
    Double Data Rate 2 Sdram.
    Then DDR3 Sdram.
    Double Data Rate 3 Sdram.
    1) http://en.wikipedia.org/wiki/SDRAM
    (Anything you see on a Wikipedia page that is in blue, is a link to more information.
    To further illustrate this,
    2) http://en.wikipedia.org/wiki/DDR_SDRAM )
    SDR Sdram specifications were all over the place. What was considered to be a standard for one manufacturer, differed for another manufacturer.
    The JEDEC organization was formed.
    JEDEC sets the standards for ram memory from DDR Sdram on up.
    Voltage for DDR Sdram is 2.5 volts
    DDR2 is 1.8 Volts
    DDR3 is 1.5 Volts.
    Ram manufacturers found that by upping the voltage requirement on high performance ram, the ram could perform, better.
    Not true in all cases, as there is high performance ram that operates at the JEDEC standard.
    Ram timings were also varied.
    Also the chip configuration
    Plus the density of the DRAM chip.
    Unless it is a really cheap, generic ram module, (Stick), there will be a manufacturers code on the side.
    With this code I can tell you the specifications of that ram module.
    I can also explain
    Feb 28, 2010 | Computers & Internet
    Does the acer aspire 5315 2077 require a certain type of memory?
    Go to www.crucial.com and click on the scan my system button to see what configuration of Memory Modules are installed on your laptop.
    Here are some other details:
    Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
    Chipset: Intel 960GML
    Drive Form Factor: 2.5"
    Drive Interface: SATA
    Maximum Memory: 2048MB
    Slots: 2 (2 banks of 1)
    Standard Memory: 512MB removable
    USB Support: 2.x Compliant
    Q: What memory goes into my computer, and will a faster speed be backward-compatible?
    A: DDR2 memory with support for DDR2 PC2-5300 speeds.
    Q: How much memory can my computer handle?
    A: 2048MB.
    Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
    Q: Do I have to install matching pairs?
    A: No.
    No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
    Q: Does my computer support dual-channel memory?
    A: Yes.
    Jan 14, 2010 | Acer Aspire 5315 Notebook
    Memory upgrade
    We have the memory you need. Memory-Up is committed to provide the best memory and excellent services for all of our customers. We know that sometimes it is a bit confusing to buy the correct type, speed, and capacity of memory for your system. Therefore we hope that these tips below would help you for buying the new memory.
    Memory Upgrade Tips
    What is Compatibility and Memory Density Issue?
    Memory module can be composed using different type of memory chips and therefore created different type of density for the module. For instance, a 512MB PC2700 DDR SODIMM memory can be composed using eight 32x16(High Density 512Mb technology) memory chips or sixteen 32x8(Low Density 256Mb technology) memory chips. As the laptops are equipped with different memory chipsets, some older laptop (chipset) would have compatibility issue working with the modules that is built with the newer 512Mb technology. Using the Not-Compatible memory will result the laptop to either not boot or only recognizing half of the memory modules. Thus that is not the correct memory for your system. Our Memory Finder and Memory Scanner will help to eliminate those problems and find the correct memory for you. We guaranteed the memory to work or your money back.
    How much memory do I need?
    Here are some general descriptions for different type of users and the amount of memory they would need for their systems.
    Normal User: The system is mainly used for checking e-mails, processing word/excel file, and web surfing. Suggestion: 512MB to 1GB of system memory.
    Power User: The system is mainly used for playing computer games, editing photos/videos, running database queries, or multi-tasking environment. (Surfing web/Processing Word/Excel File/Listening to Music). Suggestion: 1GB to 2GB of system memory.
    Super User: The system is mainly used for running large number of database queries, professional editing of photos/videos, heavy multi-tasking environment. Usually a server or a workstation would be considered as Super User due to the multiple accesses from users. Suggestion: 2GB and above of system memory.
    How much memory and memory slot do I have with my system?
    You can download our Memory-Scanner to find out the the amount of memory that you have and the memory slots that are available for upgrade.
    How many memory module should I buy?
    It is recommended to purchase one module with bigger capacity than two modules with smaller capacity. For instance, if you can buy either one 1GB memory module or two 512MB memory modules for your system, it is recommended to get one 1GB and leave the other memory slot empty for future upgrade if necessary.
    Note: For systems that supports dual channel memory mode, although memory modules need to be installed in pairs to enable Dual Channel Memory Mode, we still recommended users to purchase one bigger module than two smaller modules since Dual Channel Memory Mode has only a minimal improvement in the actual system performance.
    What if I want to mix different memory together?
    Different sizes/speeds of memory can be used together as long as their specification are qualified by the systems. For instance, a laptop can use one 256MB and one 1GB of memory for the total of 1.25GB system memory. Mixing two different speeds of memory modules would result the system to run at the speed of the slower memory between the two modules. We recommend users to use our Memory Finder or Memory Scanner to find the correct memory for your system.
    i thnk that will helpfull for u
    Oct 18, 2008 | HP Pavilion ZE5730 Notebook
    Adding a second 1GB pc3200 DDR ram!
    Are you sure memory is same (type and make) as they can have different timings and speeds.
    remove 2nd memory module see if computer starts if it does i believe memory module could be faulty
    Jul 23, 2008 | Asrock M266A Motherboard
    Intel Motherboard Logo
    73 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
