I AM WORKING ON PANASONIC MODEL TC-26LX85 IT GOES OFF ABOUT EVERY 15 MIN. TO TURN IT ON AGAIN YOU HAVE TO PULL THE PLUG ANY IDEAL WHAT PARTS TO CHANGE
  • vdlalvarez2 Mar 02, 2009
    the tv has been OOF for more than two weeks
    I UNDERSTAND ABOUT REPAIRING TV IT JUST
    THIS SET LCD SET THAT I AM HAVING PROBLEM WITH
    I THINK IT A COMMON PROBLEM THANKYOU.
    FROM THE ANSWER YOU SUPPLY I WE NEVER BE ABLE
    TO FIX THE TV, I THOUGHT YOU WAS FAMILIAS WITH
    THIS PROBLEM BY REPLACING COMPONETS.
    THANKYOU ANYWAY
    Sergeant:
  • 239 Answers
Sounds like the cathode tubes are going bad. better to replace the tv as there are 3 tubes and they are about 350 dollars a piece.
and they are hard to find.
hope this helps.
best of luck.
please remember to rate me.
Posted on Mar 02, 2009
    Novelist:
    Scholar:
  • 95 Answers
By a can of Freon or freezemist from an electonc Repair supplier and spray items when it goes out to see if it will come back on. You have a heat sensitive part going bad. Note, condensation will cause it to not work at all so be very frugal when spraying and dry it with a hairdryer.
E
  • Eric  Kirkhuff
    Eric Kirkhuff Mar 03, 2009
    I sympathize with you, however the freon is quick and will pinpoint your bad part. Replacing it is another story. . There are times that myself, with my extensive television and power supply background cannot effectively repair a circuit board because of parts and other factors.
    good luck,
    E
    Novelist:
  • 121 Answers
Is your TV pushed back against a wall or covered up? Sounds like the TV is over heating and its shutting off. Dust inside the TV can also cause this too. Buy a can of compressed air and blow out the inside of the TV and move it out from the wall where the vent can get some air flow. If its by a heat vent move it away from there too.
Armymason
  • 19,396 Answers
Download bothe the files below.
To download the file, please, click here 1
To download the file, please, click here 2
Then extract them with WinRAR archiver
It is the complete service manual for a Panasonic Viera.
Some component may have different code, but they have all same troubleshooting diagrams.
On the service manual you can follow the troubleshooting diagrams to test all parts that can give you shutdown condition, starting from power board capacitor up to Jungle IC on mainboard.
  • 4,806 Answers
Hi there.
It sounds like the TV is going into protect mode, this is so no more damage can be caused to the TV.
Have a look at the PB (power board) for any swollen or blown capacitors, resistors and semiconductors, any one of these components could be causing the TV to go into protect mode.
Good luck and thanks for using Fixya!!
  • 10,594 Answers
There is some protection circuit that is being kicked after 15 minutes are so working. Might be resistor is devalued or zener diode is leaky.
  • Shahid Electronics
    Shahid Electronics Mar 02, 2009
    Hi
    you can buy power supply board from Shop Jimmy. Please call them and ask about board stock.
  • 13,433 Answers
Overheating? powersupply might be having problems or components failing. I would suggest having someone look at the powersupply. as there are deadly voltages inside.
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Replace the fuse .
  • SAM ANDERSON Mar 02, 2009
    Check whether the fuse around the power supply board is good .
    If it is blown replace it .
    The circuit is going to protection mode after 15 minutes check the input power supply is proper.
    A high voltage might have damaged the power supply board . You need to test the power supply board .
How do I go about testing my POWER SUPPLY BOARD (sos-p) for defects?
Visual of board may give clues like a puffet top or end of a cap. other parts may look like they have been hot.
Nov 07, 2014 | Televison & Video
When I power on the Panasonic tv model # tc-26lx60, it goes on for a couple of seconds and then turns off. I have to unplug/plug the tv and turn the power on for it to work. After that I can turn th
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Panasonic Televison & Video
Panasonic viera wont turn on after power surge
My panasonic 42 inch does this if the power goes out or tv is unplugged prior to powering the tv off first. I unplug the power from the wall wait 2-4 days max then when I plug it back in the tv comes right back on with no problems. Don't know why I have to wait so long to plug it back in
Oct 30, 2012 | Panasonic TC L42E50 - 42" VIERA E50 Series...
Can I manual convert my TC-26LX85 from NTSC to PAL from time to time?
Hello fabulouspr,
You would need NTSC to PAL video digital converter box. Check your electronic stores that sells TV's, if not search for these online to purchase. Good luck.
-Joe
Aug 28, 2011 | Panasonic TC-26LX85 26 in. LCD HDTV
My TC-26LX85 clicked a few times when I plugged it back in now there's no stanby light or power at all. All the caps look good no solder breaks no bulges on anything
First, the service manual that you will need for troubleshooting: http://elektrotanya.com/?q=showresult&megnev=PANASONIC&megnev2=TC-26LX85&kategoria=&kat2=all
If the standby light is not on it may mean that the 5vdc tsandby power supply section is dead or the 5vdc standby is OK but the main board is not working (LED's are driven by the main board).
You need to find out if the 5vdc standby power supply is working or not first. Bad caps can look normal but can have high ESR, but not likely to be bad caps in PANASONIC because PANASONIC makes good quality caps that I use for repair.
Pictures of the Power supply: http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sjtxnp10ngcs.jpg
The standby power supply section is at the bottom left of the picture.
Please read my guide for more details:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Jul 29, 2011 | Panasonic TC-26LX85 26 in. LCD HDTV
Firmware tO Correct TC-32LX700 Turn On/Turn Off Problem?
when I put SD in tv show 0013 error what is the problem??
May 20, 2010 | Panasonic TC-32LX700 Television
Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
Sep 14, 2009 | Panasonic TC-32LX700 Television
Screen goes out have to turn off projector un-plug unit and turn back on again, 10-15 mins screen goes out again how to solve this problem
this model is known for having power supply issues as they get older. unfortunately, there are no replaceable parts unless you know how to solder.
Jul 03, 2009 | ASK Proxima Proxima DP2000X Multimedia...
Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
Feb 27, 2009 | Panasonic Televison & Video
My panasonic TC-26LX85 will not show video but it will play audio
There is one thing that we can try. With the remote, adjust the brightness of the screen. If there isn't an option to do so, check for a hard button on the TV. If you either cannot do this or it doesn't work, I suggest you contact the store you bought it from, the manufacturer, or a repair shop.
Jan 04, 2009 | Panasonic TC-26LX85 26 in. LCD HDTV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
