Question about Fuji FinePix A350 Digital Camera
With new batt. it only stays on for about 10 pics
Then the low batt. warning comes on. what to do?
  • Anonymous Mar 29, 2009
    The lifetime of the batteries shipped with the product was well under the specification. The same is true for the rechargeable batteries I bought: they are Energizer 2500 mAh batteries, but dont supply the power of the camera more than a day.
    I suspect some power draining when the camera is off, but it drains too much when either it is on.
    Novelist:
  • 98 Answers
Your batteries have probably come to an end of their life. You need to buy new batteries, Invest in a new set..
Posted on Mar 02, 2009
  • Sachin
    Sachin Mar 02, 2009
    If it is happening with new batteries, then you probably need to check as to why the batteries are being drained so quickly. What was the life of the battery you got earlier?
10' canam outlander 650, keeps blowing injector fuse. Check engine, DPS, and low batt amp warning comes on first, any ideas? Doesn't restart with out jump and new fuse.
amp blowing fuses ' High Lifter Forums
forum.highlifter.com > ... > [Most Popular Discussions] > ATV Accessories
Dec 31, 2007 - 2006 Can-Am Outlander 650XT Bombardier ... RE: amp blowing fusesMonday, December 31, 2007 10:31 PM (permalink). I want to use an ...
Aug 30, 2015 | Cars & Trucks
Dash warning light
Wish I could see a pic of it. Probably really means low traction, or transmission fluid is low.
Apr 02, 2014 | 1996 Oldsmobile Cutlass Ciera
C-350 zoom keeps showing low battery and beeping when opened to take pic, but in menu mood shows full, 2 new batteries
I have the same problem but not as grave.
The set can click two to three pics before low batt.
Seems to be a problem with the flash capacitor.
Try with flash turned off the thing should improve.
Nov 22, 2010 | Olympus Camedia C-350 Digital Camera
Recently purchased the Sony DSC-W290 and I have
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera settings.so if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your camera.so you may send it out and have it replaced if needed.hope this helps.thanks:)
Apr 08, 2010 | Sony Cyber-shot W290 Digital Camera
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery...
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
Nov 12, 2009 | Honeywell Power Humidifier: Furnace...
Batt light stays on and i have a nwe batt
Please have a look at the alternator as it is not charging well enough.
Rate this.
Aug 23, 2009 | 1999 Chevrolet S-10 Pickup
I get a warning which says *Battery Exhausted*. I've replaced them but still get the warning.. Any idea whats wrong?
earlier i posted solution in similary problem. maybe help you this.
solution is good batteries, Ni-Mh or Lithium, rechargeable only not alkaline. but...problem is how long you watch pictures on lcd display or how much is flash in use. if always by shooting pics used flash that means that you can with best batteries 30, 20 or less pics shooted. and of course, if you connect camera with pc, how long is cam on? just transfer pics on pc and turn the camera off. the best solution is use the card reader for pics transfering.
if is flash off, it's possible to shot 120-150 pics with Ni-Mh. with lithium i don't know, maybe 500 pics. don't use camera lcd for analysing pics it's just there for short preview.
with alkaline batt., very low quality, i shot 30 pics without flash.
i shot also very good pics at night without flash. nikon coolpix L15 can do that but you must have more praxis. alkaline batteries shooting!
after 3 pictures on display is message: warning! the battery is exhausted. what you can do? turn the camera off. wait about 10 minutes. turn the camera on, you can shot 3 or 5 pictures and than turn your camera off again.
you can repeat this few times and you be lucky if you 30 pics captured:)
REMEMBER: all this goes without camera flash!!!
flash and every zooming use more battery power! and that was all magic:).
Mar 22, 2009 | Nikon Coolpix L15 Digital Camera
Service airbag light stays on
I have a 2007 chevrolet silverado and my service airbag light came on. I was out camping with the sterio going and ran the batt low but their was enough juice to restart after about 10 min. On the way home the service light stayed on and i just fixed the problem which was a fuse under the hood in the main fuse pannel. It is very common due to low voltage on start up to blow a 15 amp fuse.
Jan 23, 2009 | 2005 Chevrolet Silverado 1500 2WD
Fuji FinePix A350 Digital Camera Logo
49 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
