SOURCE: Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
SOURCE: Door will not unlock, cycle did not finish.
Unplug the power cord let it reset..It should unlock
SOURCE: Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
SOURCE: ge front loading washer door won't unlock
I had the same problem. I didn't want to spend the money or go to the trouble of replacing the whole latch assembly with the GE latch repair kit.
I found that the plastic latch piece screwed to the door had broken and one of the two latch "fingers" was stuck in one of the latch openings on the washer. I fixed the problem by removing the broken part from the washer and drilling and countersinking very small holes (1/16" I think) in the plastic latch piece on either side of the "latch finger". I then put the broken off piece back in place and drillled pilot holes for #4 sheet metal screws in the door where the latch is located. The door liner is plastic and I think I used a 1/32 inch drill bit. I reattached the broken latch piece with two 1/2 inch stainles steel #4 flat head phillips screws from Home Depot. The screws hold the broken latch piece in place as orinilally positioned.
The repair is working fine and the door now latches like it did before the latch part broke
Or: http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=2045520&pn_=WH10X10002
Same part cost $200 direct from GE
Read more: http://forum.appliancepartspros.com/washer-repair/8379-ge-washer-front-loader-door-wont-stay-latched.html#ixzz1LmNUKfTN
SOURCE: Electrolux front load washer door won't
First try to reset the lock unplugged the power machine for a few (10) minutes (maybe release the interlock door switch). If this work, them its possible that you need door latch replacement.
To do it, turn
off power, unplug at the mains. Drag the machine out so you can see
the back. Remove the 2 screws that hold the top on, pull back or tap
the top forward (depending on the model) to unclip it. Peer inside.
You will see the door switch inside the chassis exactly in line with the
door handle on the outside. See if you manually make the mechanism
release, or if you have a stubby philips screwdriver, you can probably
unscrew the switch complely.
Keep us updated.
