Question about Kenmore 62602 Electric Dryer
Dryer will not turn on
Before this problem. I could set timer, shut the door and the dyer would start without pushing the button.
  • 57 Answers
Your motor switch is bad you need to replace the mmotor
Posted on Mar 05, 2009
Dryer doesn't run
the motor is going bad..push in the door switch on the dryer,an it start an spin the drum ,it it works,replace dryer motor,or purchase a new open....turn start button,pusn in door switch,spin drum by hand...all at same time....hope this helps...dryer may run a couple of times...good luck...michael..doctor airr appl.repair...843-384-8474....
Mar 26, 2010 | Dryers
I have an older kenmore gas dyer. as soon as the door is shut it starts running with out pushing the start button, and it doesn't shut off till you open the door . is it the start switch or the timer that...
Good day,
It could be either the push to start switch, or the centrifugal switch on the motor. You would need an ohm meter to check the push to start.
The way the system works, is the power goes first to the door switch, and then the timer.
If the timer is in the on position, it sends power out on TWO wires.
One goes to the push to start switch, which in turn goes to the motor, bypassing the centrifugal switch.
The other power wire goes to the centrifugal switch, and thru it to the same place on the motor, but only if the motor is already up to speed.
That's why it under normal conditions it will continue to run when you release the start switch.
Hope that helps.
Thanks for using FixYa
Jan 27, 2010 | Dryers
After setting dryer to the drying time and when you put the clothes in the dryer and shut the door the dryer starts without pushing the start button.
you will need to chnge the door switch. that part is bad causing the unit to run without touching the start button.
Oct 10, 2009 | Whirlpool Dryers
Dyer will not start-Start button seems to be the problem
This may be your timer or your start switch may be bad. Hope this helps!
Aug 14, 2009 | KitchenAid KEYS700LQ Electric Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer starts on it's own - won't shut off
TRY DISCONNECTING THE START BUTTON WIRES AND SEE WHAT IT DOSE WITH THE DOOR CLOSED,IF IT DOES NOT START IT YOUR START SWITCH-MIKE
Feb 16, 2009 | Whirlpool LER5636P Electric Dryer
Dryer starts on it's own when timer is turned or door is shut
its the door switch more than likely are less likely the push start button stuck
Mar 16, 2008 | Dryers
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Kenmore 62602 Electric Dryer Logo
138 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
