Question about Sony Cyber-shot DSC-S600 Digital Camera
On Off button blocked in "depressed position"
Hello
The On Off button is blocked in "pressed" mode...... "off"
The problem happened when I tried to switch off : I pressed the button but the light remained "on". I then removed the batteries....
Now the button is blocked in "off mode". When I insert batteries, a red diode blinks 2 times.. and that' s it
What shall I do ?
Jean Claude based in Montpellier,France
  • jcguigny Apr 04, 2009
    Thanks...
    So what shall I do ???
  • 40 Answers
The plastic button is broken inside the camera.
Posted on Apr 04, 2009
  • jmstad Apr 05, 2009
    The camera will need to be taken apart. Then you have 2 choices replace the switch with a new or used part (ebay) or take the pieces out and put the camera back together and reach through the hole with something to push the button on the inside of the camera. The camera is easy to get apart. It has 4 screws, 2 on the bottom and 1 at the USB port and 1 inside the battery door. With the battery door open and screws out pull the back cover loose, be careful the LCD is loose when the cover comes off, just tape it in position to hold it. The rest will be self explanitory.
All of a sudden, my Canon Rebel SLR stopped focusing and I cannot depress the shutter button when on AF mode. I can press the shutter button on MF mode, but there is no focusing happening. Do you think...
Try this...remove the lens and fire off a few shots. Clean the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol. Re-attach the lens and try it.
Apr 13, 2011 | Canon Digital Rebel XSi Digital Camera
How to activate flash in my camera? please tell me step by step.
First you can select a desired camera mode by using the Mode dial on the top of the camera. Below picture is Mode selector.
7bec22b.jpg Simply first press flash button which is shown in the fugure below.
Press a few times to the flash button. So that you set the desired flash position. Positions are shown below.
6b66403.jpg Now you can take a picture.
Mar 01, 2010 | Samsung S760 Digital Camera
How do you find and use the self-timer setting?
Hello.
Turn the function dial to the drive mode position.
Press the function button in the center of the dial.
Turn the front control dial to select the self-timer drive mode.
Use the rear control dial to to switch between a ten-second and a two-second delay.
Press the shutter-release button partway down or press the function button to set the mode.
When you are ready to take the picture.
Press the shutter button partway down to set the focus and exposure.
Press the shutter button all the way down to start the timer.
Hope this helps.
Feb 16, 2010 | Konica Minolta DiMAGE A1 Digital Camera
Hello i believe i may have protected or formatted images on my s830 now i am unable to view around 200 of the pictures it is stating they are on there skipping from from 100 to 300
You may have protected a block of images at some time, to release them do this:
Press the play mode button and then press the menu button.
Press the left/right button to select the [Protect] menu tab.
Select the desired sub menu [All Pics] by pressing the up/down button then pressing OK.
Zoom W/T Button: Protect/Release the images.
OK Button: Your changes will be saved and the menu will disappear.
Hope this helps.
Feb 05, 2010 | Samsung S830 Digital Camera
D80 Shutter Release button will not depress at all.
What exposure mode(s)? What focus mode(s)? Can you (not your wife) take pictures?
Oct 09, 2009 | Nikon D80 Digital Camera with 18-135mm...
NIKON D70S IS SHOWING r09 ON TOP LCD FRAME COUNTER AUTOFOCUS IS SPINNING BACKWARDS THEN FOWARDS BUT WONT SETTLE AND SHOOT,HOWEVER WORKS IN MANUAL FOCUS MODE HELP PLEASE.
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Jul 20, 2008 | Nikon Cameras
Cybershot H7 focus problem
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Mar 18, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Cybershot 3.2 seems to work fine until you push button to take photo
when i turn the camera on it says turn the power of and on again and the lens cover will not open
Nov 25, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Can't take photos
Dear Friend, Nothing is wrong. they are digital buttons and this happenes if signal do not reach properly. If camara is used many times and dust problem then sometimes such buttons. thats all. If You are not technical pelase donnot try to open and clean it as most of part are very delicate. Thanks Sangita
Jul 08, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
156 people viewed this question
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
