Question about Home
No water coming out of shower
I have a gainsborugh energy 2000x power shower. I was using it last night and the water seem to lose pressure and then the water stopped. I have lights coming on on the unit but no water. Help!!!
    Problem Solver:
  • 4 Answers
First you should check the screens st the ends of the hose to be sure they are not clogged. The shower head as well. Otherwise it could be the water control valve, solenoid or thermal cut off.
Posted on Mar 03, 2009
Why is my Gainsborough 2000x shower not heating the water passing through?
I sounds as if the element has failed... if you isolate the power to the shower you could test the element with a multimeter..
Apr 18, 2017 | Gainsborough Home
I just replaced a cartridge in my hot water shower handle to stop a leaky faucet, now the hot water pressure is less. It seems once cartridge is in place it doesn't have the range of motion it had when it...
you need to go back in and check your work it seems that it has been installed in a lower setting look at the directions, most shower assembly's have energy settings.usually just have to move the stopper to the farthest point to the left (counter clock wise).good luck.
Nov 14, 2010 | American Standard Home
I have a reliance 501 gas hot water tank and i bought it in 1988 and it now has a leak at the bottom so i am going to have to replace it. but i never had any trouble with it until now so it lasted a long...
hot water heaters typically don't last most then 20 years or so. AO Smith used to sell glass lines tanks that lasted longer, but were fragile. Areas with acidic water, like the west coast, tend to go quicker.
The new tankless heaters cost more, but don't waste energy heating up water over night.
A large house may need more than one tankless however, because you don't want temperature variation when someone is taking a shower and someone else wants to do laundry or dishes.
Gets really hot but only for 2 short showers. Ran d/w this morning and no hit water for about 2 hrs. Tried curcuit breaker and reset button on heater worked last night.
My guess would be that the heater elements are coated very heavily with calcium deposits and are not oeperating effecient enough to keep up with use. These can be removed and replaced or cleaned but the tank itself would also be suffering the same problem. I have never tried decalcifying a tank because the age of water heaters are usually more energy and money saving to just replace. sorry
May 16, 2010 | Water Heaters
When the shower is turned on to hot setting the water just trickles out. When on cold or medium setting the water pressure is ok. The hotter you want the shower the more pressure it loses. Any ideas?
Sounds like the filter on the hot water inlet is blocked. Is this a new shower or one that has been in use for some time ? Also , what make?
Mar 05, 2010 | Home
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Whirlpool Energy Smart water heater not hot
I think some one mis informed you, the normal temp on any water heater from the factory is 120, it should not go above that for reasons of sevear burns, as far as it't smart part it's just a name, you will lose a couple of degrees just comming torm the tank to the faucets, the water heater will allways keep the temp in the tank at what ever it is set at, it doesn't have the brains or computer to know what time of day it is but when the cold water comes in to the tank it comes thru a dip tube that goes to aprox 1 inch from the bottom of the tank, if you take a long shower and do not have a energy efficant shower head you can use up to 5 gals, per min of hot water where an energy efficant one only uses 2.5 or less and still has the same pressure at the shower head, the temp in your water heater tries to stay at the setting it is at depending on how much is used at one time meaning washing machine, filling tub or dishwasher at the same time, it lets more cold in as the hot goes out and as you know it can only heat up so much at a time and the cold water is just going across the bottom of the tank, so the name is just that no diffrent then any other water heater unless you went to a tankless water heater.
May 29, 2009 | Water Heaters
Easiboost power shower - problem
it comes on when the pressure changes so when you open another faucet it changes the pressure and makes it come on,, check your pressure regulator valve on the main line comming into the house it has a screw in the center, if you have a pressue gage put it on either the water heater drain or out side hose bib , check the pressure when turning water on and off if it changes more then 5 lbs you need to change your prv valve. pressure regulator valve,
Feb 17, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Only HOT water coming out of Redring Expressions 520 Power Shower
Hello philipknowle,
Regretfully we have cowboy plumbers on this side of the pond!! I Sent you a few links that should help. The last one is the installation manaul (12pages) The Middle one looks like a 60 page catalog. And the top one is the company website.
Please rate this response and best of wishes, Phil Pages 21-23 looks like there is a 3 year guarantee on these units.
But this looks like the manual for this item
Dec 28, 2008 | Home
Home Logo
2,074 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
