Question about Insignia 37" LCD Flat-Panel HDTV
I have a 42" 720p Insignia Plasma hdtv, same thing happend, screen just turned black but sound is still ok, tried to turn off TV for 15-20 min. but still no luck. One of the forums says it might be a fuse on the board. Got to do more research.
    President:
  • 814 Answers
This is a failure in the power supply board and maybe more. the unit should be tested by a service technician to check for the problems.The problem could be a fuse in the power supply but is probably a component failure.Insignia customer service number is 1-877-467-4289. The number for Best Buy Parts is 1-888-237-8289. If this unit is still under warranty have Best Buy service it . They might send out a mobile tech to check it out for you.Maybe they can fix it at your house If not they will take it with them for service. If not under warranty try calling a mobile tech service and see if they can troubleshoot the problem for you at a reasonable cost.If all that fails you may have to take it to a service center for service. Hope This helps you with your problem.
Posted on May 13, 2009
Plasma tv black screen
Anything from a power supply problem to loose plugs or bad connections anywhere up to a issue inside the display panel which if the case is fatal.
Voltages and waveshapes need to be checked and then boards tried depending on what if any thing is found.
Nov 06, 2012 | Insignia 50 in. Flat-Panel Plasma HDTV
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
We just bought a NS-PDP50HD-09 Insignia 50" plasma
Although we would not be able to assist you with power issue you're having with your TV, I can assure you that the issue with your new HD Insignia TV not turning on has nothing to do with the DISH Network receiver you have connected to it.
Phillip Chang
DISH Network Customer Service Representative
Feb 14, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
My samsung plasma becames black with sound but no screen after 1 min after turned on. we turn off the tv and turn on again and do it again.
Black screen on the PLasma TV can be caused by failed sustain boards and or power supply. I would inspect the caps on the sustain boards and the power supply boards first.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Dec 08, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
Watching and Suddenly turned black, but sound still worked.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It seems there is a loose connection between the board producing the picture and the screen; this is why this would happen. If turning the TV on and off makes no difference, try contact Phillips to see if they can talk you through a factory reset. If this does not work, the set may require service.
Jul 16, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Feb 01, 2009 | Insignia 37" LCD Flat-Panel HDTV
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Insignia 37" LCD Flat-Panel HDTV Logo
150 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
