Question about Sony KP-61V45 61" Rear Projection Television
Kp46v15 converence blue converence was intermitten, now the blue is out of converence. i would like to know the board number,could not find any tips on this problem
  • fsalemo Mar 02, 2009
    ordered the ic from the parts store will install it when it comes in and go from there. thank you for the information
    fsalemo
  • 10,594 Answers
You need to replace STK4278-L quantity 2 on D board
Above part is available in part store.
Posted on Mar 02, 2009
Works fine until you turn it off wait and then try to turn it on.
Must take the tv aparts.Power supply board have dying parts call capacitors?The board,where the the power a/c cord plug into it.That the power supply board.U know basic electronic's,have tools and know basic soldering?Searches the power supply board for dying parts capacitors,they alway bulges up on it tops or puff up it tops?Replaced,these dying capacitors parts,will solved this problems.No,dying capacitors on the power supply board.The Tuner board,have problems,intermittenly.That,the board where the brocasting signal cable plug into it.Tuner board,have problems alway related to ICS processor's,must change the whole board.Or tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes boards.The power supply board or the Tuner board for the replacement.
Jul 25, 2010 | Philips 32PFL5332D 32 in. LCD Television
Red, Blue and Green Ribbon on Tv
converence power supply board is the most likely problem
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Blue converence was intermitten now out on sides
If the IC's say have STK printed on them, then they are the convergence IC' s. should be three of them, replace all 3 , and the burned green coils, sometimes these burn as they supply the volts to the STK's. good luck, be safe..
Mar 11, 2009 | Sony KP-61V45 61" Rear Projection...
Converence
green is fixed so you have to move red and blue to green.
by using the remote you may find a simple converge function and open this and using arrow keys move the blue or red first to center of screen, repeat for other color you should see the lines moving toward a a white center point.
if the lines do not move with remote try manual ...menu on the set. if still no movement you have a problem on the convergence board and need a tech to fix.
A service manual will explain complex convergence to the detail .
but this might take hours to get it right.
Aug 09, 2008 | Zenith R56W36 56" Rear Projection...
My Samsung HCN4727W will not turn on. Makes a sound like it wants to turn on but doesn't. It also used to flash a red light but not any more. Few months ago a tech replaced the Conver curcuit and installed...
sounds like you need a new Misc. pwr deflection board. they arenot that exspensive if you would like a link where you can get one go to the following link and leave them an email with your model number and explain your problem, they respond quickly.
http://servicemanuals.vstore.ca/
Jun 13, 2008 | Samsung Televison & Video
Samsung pcj522r blue converence
You can get the replacement Ics at the following link you need two STK392-040 ICs they are located on the Convergence board that should be mounted on the upper right side of the set above the deflection board. You will notice two large Black Ics with STK392-040 stamped on them. Heres the link to get the new ICs and free instalation instructions with pictures.
Jun 07, 2008 | Televison & Video
Blue moon works intermittently
Take the hose handle apart and look at the bottom side of the switch circuit board. Sometimes a contact or 2 break loose from the solder and will work intermittenly. Resolder the contacts if this is the case, put back together and try again.
Mar 16, 2008 | Vacuums
Replacement or instruction needed to fix T.V. Convergence
The conversion amp ICs. Let me know if you need more info.
Mar 04, 2008 | Televison & Video
KP46V15 Convergence problem
You must have checked fusible resistor?
check convergance control panel and check voltage supply to this board.If voltage are o.k than you have to change convergance control ic which is smd ic and its on the control board.
Gopal
Dec 10, 2007 | Sony KP-46V35 TV
Televison & Video Logo
141 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
