Question about HP Officejet 5610 All-In-One InkJet Printer
Un active the fax,scann,copy
Hi
diplay(HP Officejet j3680) show "fax failure" when I send a fax and no active copy ,scanner
please guide me
    Problem Solver:
  • 12 Answers
This solution is for "older" R-series All-in-One's but it may be your solution as well. You may be experiencing a situation in AllN1's called "SCANNER SYSTEM FAILURE" where the scanner bulb may be weaker than it appears by naked sight and doesn't meet system power requirements to "pass" as good to go and thereby is passing to the printer a failure condition. In the R-Series AllN1's the ultimate solution was a bulb replacement. Which surprisingly is not as intimidating as it may sound if you might want to tackle the problem on a do it yourself basis. I can give you more details if you would like. I think you can respond to this Solution; I am new to this forum. If you can not respond directly my email address is DanDeeCo-Online@att.net.
Posted on Mar 07, 2009
Good morning,am trying to fix a hp officejet pro l7780.It can't scan,copy or send fax.Could someone assist me please?
Does the fax/scanner light come on at all? If not, then that's the problem, because that's the only part that likely needs to warm up.
Sep 11, 2014 | HP Officejet Pro L7780 All-In-One InkJet...
Lost manual, need to get copy j3680 fax
Here is a link for this printer's main support page that has links for the manual and much more.
HP J3680 Support
Thanks for using Fixya.
Jan 29, 2011 | HP J3680 Officejet All In One Printer
HP J3680 Officejet shows scanner error, will not copy or fax
typically this is a software problem. Please check to make sure you have the correct and most up to date driver installed
Jul 21, 2010 | HP J3680 Officejet All In One Printer
Scanner failure unable to scan, copy, or send a fax
Hi and thank you for using fixya:
I would recommend trying one of the followings:
1- install a fresh copy of your printer/scanner drivers.
2- check your firewall program it might be restricting the scanner software .
3- check the connection between the scanner and the computer
Good luck
Mar 20, 2010 | HP OfficeJet J4580 All-In-One Laser...
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Jul 08, 2009 | Office Equipment & Supplies
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
146 people viewed this question
Ben Johnson
