Question about Dryers
MY MAYTAG GAS DRYER IS NOT ROTATING, WE OPEN THE TOP OF THE DRYER WE SEE ONE BELT AROUND THE TUB, I WOULD LIKE TO KNOW HOW MANY BELT SHOULD BE ON THE TUMBLER. IT ALL SO LOOK LIKE THE SEAL FELT IS GOING OUT IN THE FRONT OF THE DRYER. I WOULD ALL SO, LIKE TO KNOW HOW TO REMOVE THE FRONT OF THE DRYER TO SEE WHAT'S WRONG.
  • Dryers Master
  • 19,396 Answers
There is just one belt .
Posted on Mar 02, 2009
Tub is not rotating but the belt is intact,it is an older model but dont know the model number
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 24, 2010 | Maytag Dryers
Maytag gas dryer. Belt broken. How do I open and replace it?
On the right front and left front of the panel there are 2 phillips head screws. They are about 4 inches up from the floor. Remove these 2 screws,lift the door panel out then down to dislodge the top clips. Remove the door switch wires and set the door aside. Remove 4 screws from the front drum support. @ on the right,2 on the left. Remove the drum support.Install the belt around the drum. The smooth side of the belt goes against the drum. Re-attach all the parts in front. Remove the belt access panel on the rear of the dryer on the bottom right side facing the dryer to arrange the belt around the motor pulley and tension roller.
Aug 21, 2009 | Maytag Dryers
Dryer will not spin and smelling an electrical smell.
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer will not turn
There is a belt like a fan belt that goes around the outer tub and onto a pulley that turns the tub, it may have slipped off, you should be able to take the top off of the dryer to check it.
Mar 19, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer Repair
Easy fix.
Open the top cover by insrting a putty knife in the top right and left sides where the top meets the bottom cabinet.
Lay the top to the back.
Remove 2 screws on the right and left front inside corners of the cabinet.
Remove the door.
Replace the belt around the drum and motor pulley.
Re-assemble the dryer.
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
Scraping sound when tub is rotating.
The motor turning the drum may be bad OR the spindle or axle the drum turns on may be bad as well. The belt turning the drum may have been to tight thus putting too much pressure on the drum which eventually would wear it out then causing the noise which will only get louder as time goes on.
You will need to take off the back of the dryer and possibly the top to gain proper access to the drum and motor.
Jan 14, 2009 | Dryers
Belt
Dale, You might need a flat-tip screw driver, to pry the top up, in the front !!!!! If U R standing in front of the Dryer, The Top Should have Clips on each side in the Front, Pull the Top up in Front, and should Hinge Back, to expose the inside...You should see the Belt coming around the Tub.. I hope this Helps...
Oct 26, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
15 people viewed this question
Top Dryers Experts
