I am having problems with my keyboard everytime I press f1, b, n, or the delete key the caps lock turns on. The funny thing is the capslock key don't work. Someone please help me fix this problem! I've been researching for three days and can't figure this out.
Hi there.
I'm sorry to say that the keyboard needs to be replaced, this is a common problem with certain keyboards as the binary and hexadecimal commands which link to the keys are getting confused thus you get keys doing other keys jobs as you have explained in your post. You can use a USB keyboard for the time being while you have yours replaced.
Good luck and thanks for using Fixya!!!
Firstly i would check the keybaord layout in the regional settings in control panel. secondly, if that does not work, it could be a hardware problem.
I am very sorry sir but it seems to be nothing but a hardware issue. I can understand your frustration but the keybaord has to be changed. If you do have a USB keyboard, you could use that temporarily until you can get your new keyboard fixed. All u need to do is plug in the USB to the laptop and take it from there.
Wish you luck,...
Maybe num-key is on.
hp's are realy funny sometimes they have so many hidden keys that do wonders, try the onscreen keyboard and see if that does the same.
Start/all programs / accessories / accessebility / on screen keyboard
Try pressing both the left and right CTRL keys at the same time and
see if that releases CTRL.
Go to Start / Settings / Control Panel / Accessibility Options /
Keyboard Options.
Turn off CTRL lock if it's on.
If that solves it and to avoid future problems, press "Settings"
Turn off "Press modifier key twice to lock".
Turn on "Turn sticky keys off if 2 keys are pressed at once".
Or turn off "Use shortcut"
Clean your keyboard.
Cleaning Laptop Keyboard
http://www.computing.net/howto/simple/keyboard/
hope this helps
I did that it did the same thing.
How do I do that I have not tried that yet.
I still need help with my keyboard please. I checked the regional settings and they are right. I have also tried the fn key and F11 key that didn't work either. please help!
