Question about Garmin eTrex Venture HC GPS Receiver
Unable to unlock maps
I had bought and installed the topo 2008 maps. I was out in Idaho hunting, and when I returned to NY I deleted some of the Idaho maps. Now I don't get any maps, and when I turn on the GPS it gives me a message, can't unlock maps.
I have the garmin eTrex venture hc.
Any help you can give me to be able to use my GPS again would be appreciated.
Thank you,
3 Suggested Answers
  • 638 Answers
SOURCE: map down load
You can view segments of the maps at the Garmin site and it will show you how much detail there is.
Go to http://www8.garmin.com/cartography/mapSource/topous.jsp#
and on the far right side of the page, you'll see a link to Mapsource Map Viewer Topo USA 2008. Click on that and zoom in to your area.
Yes, you can download the map segments to your unit.
Posted on Sep 28, 2008
  • 3 Answers
SOURCE: the gps keeps turning off
See "My GPS won't stay on"
http://www.fixya.com/support/t2084694-gps_stay
Posted on Sep 20, 2009
GPSCity Mike
  • 464 Answers
SOURCE: can the garmin etrex summit
The Garmin Etrex Summit does not have the ability to add maps to it.
Posted on Sep 20, 2011
I cannot locate topo maps loaded via sd card
If you have the TOPO maps loaded to an SD card and the card is inserted all you should have to do is go to Tools > Settings > Map > Info in this menu you will find your map sets if you see TOPO make sure it is activated if not you may need to re install them to the SD.
Hope this helps!
Feb 12, 2011 | Garmin nuvi 1490T GPS Receiver
Nuvi 1300
your GPS should be able to take you anywhere in the world so i don't see why it wouldn't work in canada.
Jul 07, 2010 | Garmin MapSource Topo Canada 2008...
Can i install my topo canada map on my etrex legend or do i have to remove basemap first and then load topo
No you can just load the topo and have the etrex directed to the card that you have installed and deactivate the pre-installed map
Mar 04, 2010 | Garmin eTrex Legend GPS Receiver
How to Transfer Maps to GPSmap 60csx
You have use the unlock wizard to install the key that is provided with the software. When I bought my Mapsource CitySelect, it came with two keys. The way Garmin does it is, you can install the software as many times as you want on as many machines as you want, but can transfer the maps, data, etc ONLY to unlocked devices. Last I checked Garmin wanted $75 for additional unlocks. Some data is not locked, like Topo maps and some tide points since this data is obtained (by Garmin) from the gov't, which is free for us (wel, minus taxes we pay). Contact Garmin support, they are very attentive.
May 29, 2009 | Garmin GPSMAP 60CSx GPS Receiver
I have an Etrex Vista C. I have had it for about 4 years. I am trying to install "TOPO U.S.A. 2008" USB data into the Garmin Etrex from the computor. However, it does not appear to be loading. It doesn't...
How are you installing?
You need to have Mapsource running, select the Topo USA 2008 maps to show on your screen. Use the Map Select tool, and select all the maps you want to send to the unit. Then hit the Send to GPS at the top and a pop up window asks what you want to send. Select Maps.
If this is what you have done already, please come back and tell us and we'll trouble shoot from there.
Jan 17, 2009 | Garmin eTrex Vista GPS Receiver
Map down load
Sep 09, 2008 | Garmin eTrex Legend GPS Receiver
Garmin etrex hxc gps adding m,ore map detail.
You will need to use Mapsource to transfer the maps to your GPSr unit. This should install when you install the Topo Britain program.
You will then choose which map segments you want to transfer, and the program will do the rest.
May 14, 2008 | Garmin eTrex Vista Cx GPS Receiver
Mapping
For back roads, you will need a Topo mapping program, ie Topo USA 2008 or Topo Canada 4 (you don't mention what country you are in).
Topo Canada comes on four CDs, Topo USA 2008 comes on one DVD so you'll have to upgrade your drive, or else load the maps from someone else's computer.
Feb 24, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Venture HC GPS Receiver Logo
142 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
