Question about Poulan Pro Chain Saw 46cc 20"
Clutch spocket assy replacement
I have a PP295 and I am trying to replace the chain sprocket. How do I take the nut off so I can replace it.
  • Anonymous Apr 23, 2009
    I have a pp4620avx and I am trying to replace the chain sprocket. How do I take the nut off so I can replace it. i know it turns counter clockwise but cant get it loose because when i turn it the engine spins.
  • 181 Answers
The clutch is held on by reverse threads.
Posted on Mar 02, 2009
How do i remove sprocket from chainsaw homelite ut10588
The washer needs to removed too as it may have dropped into a thread. Other than that there nothing that shouldn't be anything holding the sprocket drum; unless you have a clutch or needle bearing failure.
Note: only 6 tooth .375 sprocket is available and than it is an aftermarket one. The 8 tooth .325 spocket is no longer available.
Nov 20, 2014 | Homelite Garden
I have started my McCulloch 338 chainsaw without any problem, but the chain will not move on the chainguide, when throttled up. I have tried to move the chain by hand ( after stopping the machine !!!) but...
The chain may have come off the sprocket.
There are 2 nuts about an inch apart down just past the bar which hold it in place.
Remove the 2 nuts, take off the cover which they hold in place and the bar and chain will loosen.
Check that the teeth on the inside of the chain are on the sprocket. Pull the chain tight against the sprocket and move it. Check that the sprocket turns. With the chain set in the sprocket replace the bar, chain and cover and try turning it again by hand. If it doesn't turn don't try to start the saw as you'll do damage.
If the chain was on properly and it still won't turn the clutch may be burned out. However the fact that you couldn't turn it by hand suggests that the chain was off the sprocket.
Dec 19, 2010 | Garden
After new clutch sprocket &good bar &chain chain r bar moves prematuely and chain comes off bar nuts r tight
have you made sure that chain pitch and gauge are the same as the sprocket pitch pitches can be 3/8 lo pro 0.50 gauge
.325 x 0.50 gauge , .325 x 0.58 gauge
3/8 std x 0.50 or 3/8 x 0.58 gauge or 3/8 x 0.63 gauge
you could even have the correct drum but wrong rim sprocket on it
worst case is you could have mismatch bar and chain
make sure that bar adjjuster assy is working correctly
recheck chain / sprocket pitches and bar pitch and groove
gauge
be sure that you fitted chain to rim on sprocket correctly when you fitted bar and chain?
is the clutch cover pulling down tight ?
have a look and let me know if and what you find
cheers paul
Aug 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
How do I pull the front Sprocket inside the primary cover to change the stator
The compensator has a large nut on it and it's very tight. But, I get them off with an air impact wrench. You also have to remove the clutch assembly and primary chain. To remove the cluch assy, remove the clutch rod adjuster plate in the center of the clutch assembly by removing the snap ring. Inside the clutch is the mainshaft shaft nut. It has LEFT HANDED THREADS ON IT. Take it off and the remove the nut that holds the primary chain adjuster off and lift the front sprocket, the clutch, and the chain off all together.
The rotor should come right off but you'll have to put two bolts in the holes on the rotor and squeeze them together to get a grip on the rotor to pull it off. The magnitism force is quite strong.
When replacing the clutch and compensator, the mainshaft nut torques to 60-80 foot pounds of torque LEFT-HANDED. The sprocket shaft nut torques to 150-165 foot pounds. You'll need something to lock the primary chain while you torque the nuts or the engine will turn before you get them torqued.
Good Luck
Steve
Aug 06, 2010 | Harley Davidson FLHTCUI Electra Glide...
Compensator nut
150-165 foot pounds with two LINES of Loctite 271 red in the threads of the nut. Yeah, it's tight and you will need a primary locking bar to lock the primary so that the engine will not turn over while applying torque to the nut. A primary locking bar is a piece of rectangular metal stock cut the precise length to fit into the primary chain teeth on engine sprocket and the outer clutch shell in order to prevent the spocket from turning. Good Luck, Steve
Apr 29, 2010 | 2000 Harley Davidson FXST Softail Standard
Want to replace chansprocket,stilh avt 011
Hey mate,
There is two types of sprockets, a spur type and a ring type both are similiar to change.
Spur: remove the side cover & remove the chain and cutter bar then you will see the clutch cover and the sprocket attached, remove the little E clip in the centre and the cover will come out be careful not to loose the little roller bearing, To replace lube the roller bearing DO NOT get oil in the clutch assy otherwise you will have big dramas, and reverse the above steps... be sure to tension the chain correctly if your not sure get somebody that is qualified to check it.
With the ring sprocket it is exactly the same except you do not have to replace the clutch cover the ring just locates on a spline on the clutch cover and reassemble the same as above...
Hope this helps
Brad
Feb 05, 2010 | Garden
How to replace primary chain on a 1999 softail custom
This will be quite an involved process, just to let you know. If you have a motorcycle lift or can borrow one it makes things so much easier.
The first thing to do is drain all the oil out of your primary. Next remove the bolts from the primary, noting which ones went where as there are short and long bolts. Next under neath the primary is the adjustment for the chain tensioner. Loosen the jam nut, then unscrew the adjuster. Remove the primary cover gently, you may have to tap on it with a rubber hammer to get it loose. While removing be careful not to pull the 2 pins out of the inner primary, the are for alignment. Now you need to remove all the gasket material from the primary and the inner primary. Remove the retaining clip off you clutch hub. This is the one right where your clutch adjustment is. Once removed just pull your adjuster nut and adjuster threaded shaft out. Okay here is the fun part, in order to remove the chain you must remove both the front sproket and the rear clutch basket, etc. But before you can do this you must lock the chain from moving, Harley makes a tool for this or if you are very careful and I do mean very careful, you can take a large screwdriver and wrap it in an old T-shirt, place the wrapped screwdriver between the chain and top of the clutch sprocket. You must always lock the top of the chain NEVER the bottom. Okay the nut on your clutch assembly is reverse threaded, so while the chain is locked you turn the nut clockwise to loosen. Once lossened go to the front sprocket and repeat process, this nut is standard thread, and on tightly. Loosen this nut, then go to your chain tensioner and loosen the nut holding it on, and lower it as far as possible. remove both the nuts from the front sprocket and clutch. On the front sproket there are some items you just pull off the shaft and leave the sprocket. Note the order of removing. Okay now pull both the front sprocket and the clutch off at the same time avoiding the chain tensioner.
Now this is just advice not a must do. Inspect your sprockets for wear, if they need replacing by all means replace them...yes they are expensive...so are tow trucks! Also on some 1999-2000 models the OEM chain tension could and would fail, this doesn't make for a bad day, but a REALLY bad week! My point for about a $100 you can replace the OEM tension with the Harley auto adjusting one.
Now you are ready to replace the chain and put the sprockets back on. You should use the red loctite(sp?) on both nuts, your front nut should be tighten to 150-165 ft./lbs and the rear 50-65 ft./lbs check that number for the rear before you put it back together I may be incorrect. Once you have those tightened up put your chain tension back in the proper position. Now would be a good time to make the adjustment. Place you clutch retaining plate and adjuster, then put the retain clip back in, adjust clutch. Replace gasket for primary, install primary, remove inspection plate, put oil in, bolt plate back on.
Start it up, check for leaks, all cool, get some time in the wind.
Hope this helps,
JP
Aug 27, 2009 | Harley Davidson FXST Softail Standard...
Need 2 replace clutch on my 2001 softail duece
Remove the outer primary cover on left side. Don't forget to drain the oil first. Using a large pair of snap ring pliers, remove the clutch adjuster plate from center of clutch assembly. Remove compensator sprocket nut (very tight) and the clutch hub nut (left handed threads) and remove nut from bolt on primary chain adjuster. Grab the compensator sprocket and clutch assembly and lift out of inner primary.
Jun 30, 2009 | 2000 Harley Davidson FXSTD Softail Duece
Unit works but chain stops when pressure applyed, what oil goes resevior.
Does the motor continue to run when chain stops? Electric saws usually don't have a clutch, so I would look for badly-worn chain sprocket, or a possible sheared key in the sprocket hub, or a loose mounting nut. Remove the chain and bar, try to turn the sprocket by hand (wear good gloves). There may be some type of overload clutch built into the sprocket.
May 09, 2009 | McCulloch 10" Electric Pole / Chain Saw
How do you replace the chain drive sprocket on an Echo CS-440?
you need to replace the clutch, you woould pull the side cover off and remove the bar and chain. then you remove the nut holing the clutch on( the clutch and sprocket should be on piece) take it to your local saw shop and grab a naw one.
Mar 18, 2009 | Garden
Poulan Pro Chain Saw 46cc 20" Logo
110 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
