Question about Canon ImageClass D861 Printer
Error code e000
Turned printer off still wont print
To Reset the Copier (after getting an Error Code of E000):
(Canon ImageCLASS D861)
1) Press the <Additional Functions > button
a. It will blink green
2) Press the < # > button
a. You will see the following:
SERVICE MODE
# 1 SSSW
3) Press the < + > or < ►> button until you see the following:
SERVICE MODE
# 7 PRINTER
4) Press the < Set > button
# 7 PRINTER
# 1 SSSW
5) Press the < + > or < ►> button until you see the following:
# 7 PRINTER
# 4 PRINTER RESET
6) Pres the < Set > button
# 7 PRINTER
< YES NO >
7) Press the < – > or < ◄ > button to choose YES:
# 7 PRINTER
# 5 MLT CLEANING
Posted on Mar 23, 2009
4 Suggested Answers
  • 284 Answers
SOURCE: SYSTEM ERROR E000
Error Coed E000
- Check the connectors of the fixing film unit.
- Need to replace fixing film unit.
- Need to replace Hi Voltage Power Supply Board
- Need to replace DCNT Board.
Posted on May 30, 2010
  • 1894 Answers
SOURCE: Canon Printed LBP 5200 Error Code E000
This error indicates fuser error, its not heating up.
Posted on Aug 10, 2008
  • 76 Answers
SOURCE: Error codes
E000 and E001 is due to the laser unit, I can explain in more details.
E014 is due to the Dc motor failing
Hope this helps?
Posted on Oct 18, 2008
Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
Fixing unit error. Turn off and unplug the printer, and then contact the store where you purchased the printer or your service representative. When contacting the service representative, inform them of...
This is a print head error. If you have a cleaning option on the printer menu, please try that. If you dont, then you can remove the in cartridge and try cleaning the head with 1-tips and water or alcohol.
Jan 19, 2014 | Canon LASER SHOT LBP-2900 Printer
An error code keeps coming up when we go to print.... E000 what is this error?
Thank you for posting your question in fixya.com.
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode (doing a reset).
Here's what you need to do:
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
I hope this helps!
Please let me know if it doesn't work or if you need my help.
Thank you very much.
Carlo
Dec 13, 2012 | Canon MF8100
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
Canon Imageclas D860 Error Code E000 Have tried unplugging the unit and then restarting to no avail
E000
The error history indicates any of the following error codes 4 times: E001, E002, E003.
Action 1) Clear the error.
Execute '#4 PRINTER RESET" under '#7 PRINTER' in service mode to clear the
error.; then, turn back on the power.
Apr 14, 2009 | Canon imageCLASS D860 All-In-One Laser...
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Error codes
Hope this helps?
Oct 17, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Canon ImageClass D861 Printer Logo
379 people viewed this question
old marine
old marine
