Question about Vizio GV42L 42 in. LCD Television
Vizio LCD TV SV470XVT1A displays horizontal or vertical lines. On Power up the screen alternates between many fine vertical lines, and many fine horizontal lines, then stabilizes with either horizontal or vertical lines but no picture. Audio is just noise. Cannot select menu from tv or remote. Cannot get cable channel input. Unplugging from wall for several minutes does not correct the problem. Powering off for several hours, then back on does not fix the problem. At least 2 of 8 TV's have developed this problem. One was corrected by powering off and back on. The other still will not power up correctly. What may be wrong? What can be done to correct the problem?
  • timtation123 Apr 04, 2017
    First try different inputs, even if you have to hookup your cable box etc. with coax/ video cables since it's hard to see what you're doing. Your t.v, cable box, blue ray, etc. might be changing formats. For example going from 1080i to 720p. If this is it, you can set any device up on a fixed format to prevent this from happening because it's very annoying, make sure you set it to a format that your t.v supports. Other symptoms include: picture no sound, sound no picture, picture blinks in and out for no reason, t.v no longer supports one of the formats it's receiving from the cable box, PlayStation etc. causing squiggly lines or just a bad/loose cable going to your t.v.
    Top Expert:
  • Vizio Master
  • 80,668 Answers
Remove the TV cabinet to expose the circuit boards and plug and unplug the connectors the main circuit board, that many times will fix the issue.
Posted on Mar 30, 2017
toolkits
  • 1099 Answers
SOURCE: My Vizio SV470XVT1A, when turned
All plasma an lcd TVs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They can sometimes be fixed, but it is a pain. An yes I have done it, and the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 03, 2010
  • 362 Answers
SOURCE: I just purchased a vizio lcd model sv470xvt1a
Hi martnezlizz, I will be glad to help you with your problem,
  1. You must have 2 video sources connected to the tv.
  2. Connect your main source, cable, antenna or satillite.
  3. Connect your second source, dvd player or game console.
  4. Press the PIP button on the remote.
  5. Press the Pinput button on the remote.
  6. Choose which input you want to use as second source.
Detailed instructions can be found on page 55 of the manual and here is a link to download it. http://www.vizio.com/assets/0/92/94/118/de070116-91ba-4d18-b436-f3c168e03b53.pdf    Let me know if I can assist further and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 12, 2009
  • 36 Answers
SOURCE: Sony Bravia 46Z4100 has a thin vertical red line on the screen
I assume that when you get the line you lose the picture, if so, you have vertical collapse, either a dry joint in the vertical section or capacitors or vertical I.C., I would doubt that the scan coil would be O/C as that is rare. if you can't do it yourself I suggest taking it to a repairer, as it should be an easy fix...Hope that helps...Phil
Posted on May 19, 2009
SOURCE: I lose Audio from internal speakers Vizio
This issue is actually caused by my cable box. Access the audio SETTINGS on Hand held Cable Remote, and turn on the HDMI and or "Digital Audio Out" option. found on 'more' settings list. This should fix the issue. I had assumed the Cable companeis 'Boot' would have installed this feature during its initialization.
Posted on Dec 20, 2009
welcomejee
  • 10594 Answers
SOURCE: I have a Vizio SV470XVT1A
Let me know do you get on-screen display or Menu in screen?
Thanks.
Posted on Sep 28, 2010
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
I have a Vizio E320I-A0 and it has multiple vertical and horizontal lines on the screen, how do i fix that?
Probably the T con board is faulty. T con board is the one which drives the lcd pixels. Chekc the video to identify the t con board. Also try to remove the connection to T con board and reconnect it. some times bad contact on those connectors can lead to such problems.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
www.electro-medical.blogspot.com
Sep 22, 2015 | Vizio E320i-A0 32 Class LED Smart TV
Any idea on what is causing these issues with Vizio TV? Black lines horizontal, shadow vertical.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD TVs will be similar, irrespective of its screen size and brand.
Jul 27, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
Vizio vw42lfhdtv10a static lines
Sounds like AC line interference. Use an external line filter.
Jun 05, 2013 | Televison & Video
My Vizio SV470XVT1A, when turned on has vertical green lines, when playing a movie the lighter shades of color are good but all the dark shades have green vertical lines through them. I am trying to fidure...
Good luck.
Aug 03, 2010 | Vizio SV470XVT 47 in. LCD TV
Vizio GV42L 42 in. LCD Television Logo
2,236 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
