Question about DISH Network 311 DTV Receiver
Receiver does not turn on
Where the channel numbers should be shown, only four horizontal dots come on
Thanks
  • 374 Answers
To many variables to get into here. Give me a call and we will solve this issue.
Jim
912-222-5778
Posted on Mar 03, 2009
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
Horizontal dots on right side of page, every 3"
check fuser and clean it, maybe you have to replace upper fixing film or lower pressure roller
Nov 25, 2009 | HP LaserJet 5p Printer
I can get 110 or 119 directly to receiver model 311 but switch 21 will not switch over
Hi
Thanks for using FixYa. As per the issue you described, I think you are not able to switch to Channel 21. It means that it has either been deleted from the projection TV or you have set the parental control guides. To correct the former, access the Channel controls by pushing the "Menu" button and maneuver the channel icon, then press "+". Select "Favorite Channels," and then the "+" button again. Then type the number of the channel (21) you are not able to watch and press the "+" button one last time. To access the parental control channels, press "Menu" and maneuver the Parent icon, and press "+." Enter your four-digit password and use the arrows on the remote to change the overall settings. After performing this procedure hit the "+" key one more time. Now you will be able to watch channel 21 as before.
Please tell me the model number of your Unit so that I can provide you with model specific information.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2009 | Televison & Video
I get 110 direct to receiver or 119 direct to receiver (dish 500) but when I use the sw21 switch I only get one
Hi
Thanks
Rylee
Sep 16, 2009 | RCA DISH Network(r) 311 Satellite System
My dish remote wont connect to the dish reciever
If you have a single mode receiver, you need to open the panel in front and push system info.
A channel number will appear near the bottom of the list of information... it may be between 1 and 15. Push the record button on your remote control. (the black button with the red dot). If the channel number changed, then your remote and receiver are not on the same channel. Assume your channel was #1. when you first pushed sys info. You need to program your remote to #1. On your remote, push the Sat button until all other top buttons light up. enter the digit 1 and then the # key. Press the record button 4 times. You have to make sure you have the correct color key inserted in the remote control. If you have a dual mode receiver, one remote key will be green, and the second channel remote will have a blue key. Go to the Dish network website tech portal ...Google will help you find it, for complete instructions from the horse's mouth.
May 03, 2009 | DISH Network 311 DTV Receiver
HORIZONTAL OUTPUT TRNSISTOR SHORTS WHEN POWER ON TV
ALL the next is with the tv unplugged (NO NO power)
  • resold the jungle (video processor) all around
  • following the horizontal drive pulse path and arriving to the horizontal area just after the horizontal transformer and in the base of the horizontal DRIVER there is a electrolytic capacitor (if this chassis uses this one,) Change it (maybe is dry)
  • solder all components i just told you in the last step. horizontal driver, transformer, etc
  • remember:
  • if a transistor is blowing with no reason (there is a reason: the collector receives 130 volts but cannot hold it forever, It has to be in some place. if the switching pulse doesn't arrive to it the transistor throws this 130 volts and burning itself. i hope it is help full.
Apr 15, 2009 | Televison & Video
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
Motion detection problem with surveillance cameras
under motion settings you must select all or parts of the screen to be viewed.you may have them all unselected.
Oct 27, 2008 | Nuvico NVJV-4000N Video Recorder
Dish dvr uhf pro remote
i did everything i could at the moment but i got the soultion hold down the SAT button and if your control has a [green R] press it at the same time then it should swith to sat hold it down for like 30SEc it works trust me.............
Feb 22, 2008 | Universal Remote Control Dish Network...
Stinkin' Scanner
You can download the manual from the link below: http://support.radioshack.com/support_electronics/doc61/61172.pdf I would reset the scanner to factory defaults as per the instructions below: Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | Radio Shack Pro-94 Scanner
DISH Network 311 DTV Receiver Logo
48 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
