Question about Philips 42PF9431D/37 TV
Enable child protection and parental control
How do I enable child protection and parental control on a PHILIPS 42PF9431D/37?
  • andreaerr Mar 03, 2009
    Excellent! Thank you so much.
  • 362 Answers
Hi andreaerr
Here is a link to download the manual for your tv, beginning on page 28 you will find several different ways to lock channels, ratings and time of which to lock.
http://www.p4c.philips.com/files/4/42pf9431d_37/42pf9431d_37_dfu_aen.pdf
If I can provide further assistance please let me know. Please rate this solution.
Lone99star
Posted on Mar 02, 2009
Parental control configuration
Hello, an image would be helpful or give me ur id and pass ot teamviewer i will help, but before this check which ip or mac adress u have provided ;)
Feb 05, 2014 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
I suggest you contact your internet service provider for advice.
Oct 08, 2017 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
No picture on philips model 42pf9431d/37, how to fix?
You will more than likely need your capacitors replaced. That is the most common problem with these.
Mar 17, 2011 | Philips 42PF9431D/37 TV
My DVP 3962/37 is asking for a password and I have no idea what to do! It is a Phillips DVD player.
This sounds like the child access control lock or the disc lock to me. One feature of Philips machine's is a child access lock which you can set to a level of your choice. When the machine prompts you for the password try entering the following code 136900 then press enter this is the default password code for this particular model (see your user manual page 44, the manual can be downloaded from the Philips website) you can change this password if you wish after this. To deactivate the child lock select Setup menu then pressing up or down select Parental. the the protection level is rated from 1 to 8 select the level you wish by using the up or down buttons and then press enter it will then ask for the password (default 136900) level 8 will deactivate the parental control.
Hope this helps,
James
Apr 19, 2010 | Philips Televison & Video
Philips 42" flat screen green light comes on then turns to red . TV will not come on I have unplug it 4 to 5 times before it turns on
you ave a faulty power supply board, and the tv put on protection mode, check for bad caps, if you know how to do it.
if not check the part number on the board and google it to get a new one and replace.
Fosg2000, Rate me Please !
Mar 15, 2010 | Philips 42PF9431D/37 TV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a philips magnavox ms2730 c tv 27 inch , my parental lock is enable but i didnt enable it and i cant get it turned off, i was hopping i couldnt find a default password .
I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set).
Philips sets use 0711 as the override code to defeat parent lock. You may need to enter the code twice if it says "invalid code" the first time.
Using the remote control:
Press the MENU key. Scroll up or down until you reach AUTOLOCK or SMARTLOCK. Press the "right arrow" key. Enter code 0711. Enter it again if it says invalid code.
Once in the AUTOLOCK or SMARTLOCK menu:
Scroll to BLOCK. Press the "right arrow" key. Scroll to BLOCKING OPTIONS. Press the "right arrow" key. Scroll to MASTER DISABLE. Press the "right arrow" key. This should unlock the parental control.
Hope this works for you. Thanks for using Fixya!
Mar 05, 2010 | Philips MS2730C 27" TV
Philips 42PF9431d/37 behaving erratically
I would have the technician check out the key board assembly (button panel for lamen's terms). If not,then it could be a problem on the IR reciever board that is causing the small signal board to behave rather unusually. Tell him to check the ir board,there should be a surface mounted capacitor that will read shorted on a diode scale under the infra red diode. If that solves it,then it should cost you no more than 60$ reasonably. The logic board wouldn't have anything to do with the button changing.
I have also worked on a lot of this whole series of philips plasmas, and the control board is the least likely suspect from my experiences
Oct 16, 2009 | Philips 42PF9431D/37 TV
No sound form digital out of my Philips 42PF9431d
try installing the updates on philips website it fixed mine.
Feb 23, 2009 | Philips 42PF9431D/37 TV
The web
Go to online and download Mcafee for free. with parental control. go to the settings and enable parental control, protect it with your password
Jun 13, 2008 | Medion Computers & Internet
Philips 42PF9431D/37 TV Logo
150 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
