When I set up the DNS page the setup does complete
When I set up the DNS page the setup does not enable and turns off therefore dns is still disabled what am i doing wrong ?
Thompson adsl router model 585
  • 611 Answers
Reset it
Posted on Mar 04, 2009
C:\Users\Nelson>ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : Dragonlorde Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP...
It does not show as connected. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done! Test it with network cable to pc before trying a wireless device.
Default IP is 192.168.1.1 Use web browser to access. User: Admin Password: password.
There is reset option in the back. Hold it in till it cycles. This will clear all custom settings.
http://www.netgear.com/images/WNR3500Lv2_DS_07Jun1118-5898.pdf
Nov 08, 2012 | NetGear WNR3500L100NAS Rangemax WirelessN...
Error 105 (net::ERR_NAME_NOT RESOLVED) i cannot open any internet page..what should i do?
Hi There,
I Just found this sollusin:
Turning off and disable DNS pre-fetching may actually solve and fix many web page not loading issue in Google Chrome. Here's how to disable and turn of DNS prefetching in Google Chrome.
  1. In Google Chrome, click on Tools menu (a little wrench icon), then go to Options.
  2. Click on the Under the Hood tab.
  3. Under "Privacy" section, untick the check box for Use DNS pre-fetching to improve page load performance.
4. Click on the Close button.
5. Refresh to reload the web page.
SOURCE
Jan 06, 2011 | Google Chrome
I can only connect one laptop to the internet. When i turn on the second one it makes the first laptop loose its connection with the internet. My service provider says its the router. Can u help?
Hi! I think you have an IP conflict on your laptops. Do this: goto control panel and open the network section and put a fixed IP address for both the laptops, lats say: LapTop1: IP: 192.168.0.10 LapTop2: IP: 192.168.0.20
And put a DNS number in the same section where you put the IP numbers. The DNS number is the IP number of your router. WARNING! your router IP address must be in the same region as your laptops. Lats say Router IP: 192.168.0.1 than your DNS address on your laptops are 192.168.0.1.
Check in the router of some security restriction like how many users can be connected through WiFi connection, check for firewall enabled or disabled, if enabled try disable it and try to connect now.
I hope this solution will help to solve your problem.
Dec 29, 2010 | EnGenius ESR-1221 EXT Router
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Mar 13, 2010 | Linksys WRT160N Wireless Router
Windows 2003 SBS Standard Edition ? IP Address: 192.168.1.5 Linksys WRV210 ? 192.168.1.1 Screenshot Router setup page: http://img205.imageshack.us/img205/3889/capture1w.jpg I have setup a preferred...
hello, is your server 2003 setup as DNS server??? if so have you configured forwarder for non- local access? is that a home? or business? is it work do you not have a static public IP address.
here whats happening, when you manually give client the DNS they can resolve everything local fine but when a request for outside world is sent your server doesn't know what to do with it. log on to server open up your dns console, right click on your domain, then select properties, find forwarder tab and add a any reliable public DNS server there ( ie I use 4.2.2.1 (att)) server pretty quick and reliable.
so next time a request is sent to your server and server doesn't have that information it forward that to the public DNS and you will be good to go.
but from your setup i am gathering there is plently you do to improve your network and reduce your headache of manual work.
typical setup: 1- setup DNS with forwarder
2- Setup DHCP on Server instead of router ( trust me its easier than you think)
3- put all setting to for clients in DHCP options
4- reserve IPs for servers/prineters/switches etc.
5- set all clients for DHCP
6-disable DHCP on router.
let me know if your need help setting it up.
i hope this helps
good luck
Amar Sondhi
Dec 07, 2009 | Computers & Internet
Vodacom gprs settings for i-mate
If you are with Vodacom, just dial *111# , select “Device Setup” and follow the instructions.
Name APN Username Password Primary DNS
Vodacom internet None None 196.207.40.165
Secondary DNS
196.43.46.190
1. Try leaving out DNS addresses first. DNS servers are usually assigned automatically to your device on connect.
2. If you are using Vodacom and GPRS does not want to work, first call customer support and make sure your sim is activated for the “internet” APN.
Apr 09, 2009 | i-mate SP JAS Cell Phone
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
MTU setting
Browse to the router's setup page, should be 192.168.1.1 or 192.168.1.0 and log into it. You just have to change the MTU. Put it to 1500.
Once logged in to the router, go to :
Setup
Basic Setup
Wireless Setup
Internet Connection Type
Connection Type = Static IP
Internet IP Address = 192.168.0.1
Subnet Mask = 255.255.255.0
Gateway = 192.168.0.1
Static DNS 1 = 192.168.0.1
Static DNS 2 = 192.168.0.1
Static DNS 3 = 192.168.0.1
STP = Enable
Optional Settings (required by some ISPs)
Router Name = client-mode
Host Name = 2WIRE383
Domain Name = [empty]
MTU = Auto
Please remember to rate all users who assist you for free :)
Sep 29, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
