Question about Sharp AL-1641CS Copier
We have a Sharp 1641CS copier and the drum light came on a few weeks ago, we replaced it, and the light never turned off, now it blinks, and the will not copy at all? Help!
  • tt7172 Mar 03, 2009
    Resetting the drum counter worked! YEAH! Thank you Marcus_25!
I got a reply from Marcus_25 to reset the drum counter, that fixed the problem! I am so happy!
Posted on Mar 03, 2009
  • 37 Answers
If you will replaced the drum you should reset the drum counter .
To reset follow these steps:
Step1: Press continuously Clear key then press Exposure key then Clear key then Exposure key
Step2: You are inside the simulation if the display turns off but if not do again step1
Step 3: Press 24 then press print button then press 7 then print button
If not canceled try step4
Step4: Do step1 to step2 then Press 24 then press print button then press 6 then print button
MY AL-1641CS LEAVES A THICK LINE ON THE PAPER. I
If the drum is rotated in the proper direction, it should be clean. If the line on your copy is in about the same location from to back as the line on the drum then your only option is going to be to replace the drum unit. The drum unit contains a drum cleaning blade that is supposed to clean the drum as it is being rotated. This is apparently not working in your case. These cleaner blades can be replaced if you have someone locally that can do it. The cost of a cleaner blade is about $20.
Good Luck and Thank You for using Fixya.
Jul 09, 2010 | Sharp AL-1641CS Laser Digital Copier
Tip
Sharp AL-1641CS Copier Manual Download
Free Sharp AL-1641CS Copier Manual Download
Models: Sharp AL-1632 / Sharp AL-1641CS
Would you like to review the features of the Sharp AL-1641CS Copier?
Have you lost your Sharp AL-1641CS Copier Owner's Guide?
Would you like a free digital, searchable, pdf version of the Sharp AL-1641CS Copier Manual?
Follow this link
(& click FREE) to download a pdf version of the Sharp AL-1641CS Copier documentation.
I hope that helps.
___________________________________________________
on Jul 24, 2010 | Office Equipment & Supplies
Tip
Follow this link
I hope that helps.
on Jul 24, 2010 | Sharp AL-1641CS Laser Digital Copier
Reset the copier counter AL-1641CS
Which reset are you trying to preform
the counter for the drum unit ?
Apr 01, 2009 | Sharp AL-1641CS Copier
My Sharp AL-1641cs won't print. Just keeps flashing red drum.
SOUNDS LIKE YOU NEED TO REPLACE THE TONER CARTRIDGE, THEY GO THRU LONGER WARM-UP PERIODS WHEN THE TONER GETS LOW AND IF YOU LET IT RUN YOU WILL SEE RED LIGHTS LIKE STACKED CANNON BALLS, WHICH MEANS ITS OUT OF TONER
Feb 18, 2009 | Sharp AL-1641CS Laser Digital Copier
Locked up AL-1642CS with blinking Drum Light
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Nov 07, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp al1340 copier won't copy
those dots mean toner, when they blink it's empty. replace the toner cartridge. open the front door and pull it out. pull the seal on the new toner and slide it in. shut the door. that was easy! Good Luck!
Sep 19, 2008 | Sharp AL-1641CS Laser Digital Copier
Red Drum Replacement Light
If you saved the instruction when replacing the drum, did it give you a procedure to reset the drum count?
Jul 01, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AL-1641CS Lase Copier
http://www.retrevo.com/s/Sharp+AL-1641CS?rt=pd
Here is the location for your copier manual. You'll be able to view & download. Good Luck :0)
Jan 10, 2008 | Sharp AL-1641CS Laser Digital Copier
Drum light
Check a service manual on resetting the drum counter. You have to reset this counter to tell the machine it has a new drum
Aug 25, 2007 | Sharp AL-1641CS Color Copier
127 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
