Question about GE Microwave Ovens
I have a GE JVM240 spacemaker microwave oven. When I turned it on I heard a loud pop, the sound of the microwave seems louder and it does not heat. Everything else works fine. Moisture could of been a factor due to I was boiling a pot of water on the stove without using the fan at the time.
  • GE Master
  • 8,871 Answers
Actually, you should always use the hood vent exhaust fan when you're cooking on the stovetop, but I don't think that caused this problem, although it's possible.
Instead I would most strongly suspect a shorted high voltage rectifier diode, which is a pretty easy fix.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Mar 06, 2009
2 Suggested Answers
MicrowaveSvc
  • 8871 Answers
SOURCE: I have a GE JVM240 spacemaker microwave oven. When
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
G.E. spacemaker microwave stopped heating,made louder than normal sound,smelled odd.
The magnetron has failed, "heats food" to repair the unit will approach the cost of a new microwave oven.
May 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Oven not heating. runs but no heat. GE Spacemaker (11 years old) Light works, table turns. Seems a little louder when turned on
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 26, 2010 | GE JVM1440 Microwave Oven
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
Jun 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
Oven humms and doesn't heat anymore....
if you say 'seems like common problem with this model' then just replace it and get another good model.
it gives peace in long run.
May 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE JVM240 spacemaker microwave oven. When I turned it on I heard a loud pop, the sound of the microwave seems louder and it does not heat. Everything else works fine. Moisture could of been a...
Mar 02, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Microwave Ovens Logo
182 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
