Question about Apple iPod nano
Ipod is locked forget password and recently sold orig. computer.
  • Apple Master
  • 13,433 Answers
Hey,
the solution to that problem is here
http://www.fixya.com/support/r977231-disabled_or_code_forgotten
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 02, 2009
IPod is disabled, and I forgot my password / passcode.
The screen lock is available on the iPod Touch, as well as recent models of the iPod, and iPod nano, allowing you to set a 4-digit passcode to lock the screen. This is to prevent others from using your iPod, but it is not an impregnable security device. If you forget the passcode, you can quickly and simply unlock the iPod by connecting it to the computer you normally use to sync your iPod with iTunes.
Dec 08, 2013 | Apple iPad 64 GB WiFi
Tip
How do I unlock iPod Screen Lock if you forget your password?
<p>The lock screen on an iPod can be a blessing and a curse. The function does a great job of keeping unauthorized users from snooping in your files, but if you forget the password, it does a great job of poking around you and in your files, too. Forgetting a password is automatically locked iPod into a worthless piece of plastic and circuits, however. You have two options: a quick and painless, and if that fails, the other is slow and clean everything off your iPod ... but you will regain control of the device at the end. <br /> <p><br /> <p>1. Sync your iPod with your main computer, linking the equipment with the supplied USB cable and then open iTunes. Synchronize the two, and open the iPod in some cases. If you do not have access to the main computer - the computer that you used for the initial setup of the iPod to run - you need to restore iPod to factory settings. <br /> <p><br /> <p>2. Connect your iPod to any computer that has iTunes. <br /> <p><br /> <p>3. Open the iTunes software. <br /> <p><br /> <p>4. Click the list to your iPod in "Devices" in the left pane of iTunes. It may take a few moments for the software needed to register the device is connected, so be patient if you do not see in the first place. <br /> <p><br /> <p>5. Click "Restore" in iTunes main window. The first phase of the recovery process takes place; progress can be seen in iTunes. After the first step is completed, iTunes, or instruct you to disconnect the iPod and the battery or asks you to leave it on to complete the process. Do what is asked. <br /> <p><br /> <p>6. Wait for the second phase of the recovery process occurs. This time, the progress bar on the iPod itself. <br /> <p><br /> <p>7. Run the installation process for your iPod after the second phase is completed. The procedure is the same as the first time you sync your iPod. After installation is complete, you'll find the iPod screen lock off<br />
on Jul 21, 2011 | Computers & Internet
Tip
How to unlock the iPod Touch, if you forget the password
<p>The screen lock is available on the iPod Touch, as well as recent models of the iPod and iPod Nano, giving you a 4-digit password to set the screen. This is to prevent others from using your iPod, but it is not a safety device impregnable. If you forget the password, you can quickly and easily unlock the iPod by connecting it to the computer you normally use to sync your iPod with iTunes. You can then open the iPod and reset the lock to a more memorable password. <br /> <p><br /> <p>1. Connect the iPod Touch to your computer via the USB cable. <br /> <p><br /> <p>2. Wait for iTunes to access and synchronize with your computer. <br /> <p><br /> <p>3. Take your iPod Touch from your computer, clicking on the "Eject" to the input side of the iPod under "Devices" in iTunes. <br /> <p><br /> <p>4. Disconnect the iPod Touch from the USB cable. IPod touch will turn on and will be available. <br /> <p><br /> <p>5. Tap the menu "General" on the iPod Touch. Tap "Passcode Lock and tap either" Turn off access "or" Change. "When you click" Change Password ", you can create a new password. <br />
I forget my password on ipod touch
You can unlock it by simply connecting it to the computer that it was originally loaded from. iTunes will unlock the iPod for you, but it will not reset iPod password. Of course, as long as you don’t need to lock it again, that should be okay. The iPod will not lock automatically — it only does so if you specifically select the “lock screen” option.
There are several hacks and workarounds out there that will supposedly let you clear out the password by editing files in the iPod’s control directories through disk mode access, but I have never been able to consistently reproduce these, particularly on more recent firmware versions.
The only sure-fire way to actually remove the password entirely is to perform a “restore” on your iPod, which will erase everything on it, basically returning it to factory settings. If you’re using automatic sync, however, it should be almost trivial to reload it from iTunes, although it will take a bit of time.
Source:
How to reset iPod Password?
Jul 22, 2010 | Apple iPod touch Second Gen (8 GB,...
How do I unlock my ipod it won't unlock . It was recently dropped in water by my nephew. It was working again today after I let it sit for about 2 weeks. I was able to turn it on and it lit up like it used...
did you forget the password or is it not allowing you to even put in a password. I will start with a how to reset the password. If this does not work please let me know by following up with a comment and i can instruct you where to go from here. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Jul 06, 2010 | Apple iPod touch
Tip
How to unlock an iPod Touch if you forget the password
<p>If you have an iPod touch, you have the option of a password that Apple calls an access code, protecting your data set. Someone trying to access your iPod, after unlocking it or put it, the access code required to do so. However, if you forget your password or the wrong type, you will eventually see a warning that the iPod touch has become disabled. In order to unlock the iPod touch after you forget the password and still access your content, you must connect to the computer that was last synchronized. <br /> <p><br /> <p>1. Connect your iPod touch to the computer the last time you synced the music. Open iTunes if it does not open automatically. <br /> <p><br /> <p>2. Select your iPod touch in the Devices list and click the "Summary" tab in iTunes. Click "Restore" and when prompted, click "Back Up" button to make the backup to store your iPod touch in iTunes. <br /> <p><br /> <p>3. Click "Restore" when prompted, after the backup saved. After the restoration, click "OK". <br /> <p><br /> <p>4. Choose the most recent backup from the drop-down in the "Set up Your iPod" screen. Click "Continue" to restore your iPod touch. <br />
Tip
Resetting an iPod if you forget your password
<p>The iPod is a security measure to prevent unauthorized access to your personal media player. Apple included an option to set a password to be used to unlock the device at startup. If you draw a blank password, you can still have the ability to unlock the device, but the process depends on the model of the iPod. IPod Touch owners to restore the device to a password reset code. Other iPod owners need only plug it into iTunes to lock the screen around. <br /> <p><br /> <p>Lock the iPod <br /> <p>1. Connect your iPod to your computer you normally sync your device. <br /> <p>2. ITunes load. <br /> <p><br /> <p>3. Click the "Eject" on the right to offer your iPod under "Devices" in the left column of iTunes. The iPod will be unlocked. <br /> <p><br /> <p>4. Select the "Extras" on the iPod. <br /> <p><br /> <p>5. Select "Lock screen". <br /> <p><br /> <p>6. Select 'Turn Off Screen Lock. " <br /> <p><br /> <p>Unlock iPod Touch <br /> <p>1. Connect your iPod Touch to your computer. <br /> <p><br /> <p>2. Open iTunes. <br /> <p><br /> <p>3. Click on the iPod Touch icon on the left "Devices" section column. <br /> <p><br /> <p>4. Select the "Summary" tab. <br /> <p><br /> <p>5. Click "Restore" and confirm the prompt action in the resulting pop-up. Follow the wizard prompts for the restore process to complete. <br />
My ipod is locked and it the hold switch is not in the locked position. I have restored my ipod and it is still in the locked position. Please help me!
My ipod is locked and i forget the password. I recently sold the computer that my i tunes were loaded into how do i restore my ipod nano.
Feb 22, 2009 | Apple iPod nano
Ipod lock code
My i pod ( 80gb) screen get locked & i forget the code, please advice
Mar 09, 2008 | XO Vision EM200VID MP3 Player
I for got my code and cant unlock
my friend sold me a ipod and the screen got locked and he forgot the password
Dec 14, 2007 | Apple iPod MP3 Player
Apple iPod nano Logo
21 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
