Question about Whirlpool LER4634J Electric Dryer
Dryer wont turn on
I used my dryer less than 12 hours ago and everything worked as normal. I tried to use my dryer this morning and it wont turn on. I have only had the dryer for less than 2 years. I have already flipped the circuit breaker and that did not work. Any suggestions? Thanks.
  • Anonymous Mar 04, 2009
    Dryer was running then stopped and will not restart.
  • Anonymous Mar 08, 2009
    Dryer does not turn on when the start button is pushed
  • 1,122 Answers
It sounds like the door switch or main fuse has blown,check the door switch,click it in and out to see if it has the clicking sound,if not replace,you can check the main fuse by removing the back panel,it is located on the blower box,let me know-mike
Posted on Mar 05, 2009
My 40" Soniq tv wont turn on?it was working this morn.I switch it of abouut 5 hours ago and ive tryed turning it on for about an hour?Ive unplugged tv from power board for 10 mins,plugged it back in and it...
Are you tech savvy?...I can give you some voltages to test if you're able to do that, if you aren't then you have 2 choices, take it somewhere to be serviced but expect to pay between 75 and 100 dollars an hr for tech time plus parts or replace the set with a new one.
Feb 11, 2018 | Televison & Video
Amana electric dryer whining when started
Is ther anything caught between the drum and the back of the dryer. run you finger around the back edge of the drum inside do you feel anything caught
Feb 02, 2014 | Amana Dryers
The key wont turn over the ignition cylinder. it was working fine 12 hours ago now it wont let me turn on the vehicle. ive tried wiggling the steering wheel. made sure it had plenty of fuel, everything is...
alot of the time the antitheft security goes bad and can lock your ignition up. Is there a light somewhere on the dash that says security? Or has a picture of a car with a pad lock on it? If so, this is your problem. Read about it on this link. Might have a fix for ya too.
May 17, 2011 | 2003 GMC Yukon Denali
My Samsung HLR5067 was working fine last night. I left the house open and it dipped in temp (only to 40 degrees or so though)...Woke up this morning and it wont turn on at all. Just beeps a few times,...
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
Dec 06, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
95 Eagle Vision - Suddenly Wont!?
Hi! When last u service,check your battery,starter ,alternator etc?Remember what don't happen in a year will happen in a day.Go to a service shop and get a system check and service.
Jan 25, 2009 | 1995 Eagle Vision
Freezer working, not making ice; refrigerator not cooling
Look for excessive frost build up in the freezer, there may be a problem with the defrost cycle.
Dec 29, 2008 | Maytag MSD2756G Side by Side Refrigerator
It shows 8.8. and does not start
After having this problem I believe I found a solution. I think the problem is related to tha ambient temperture of the room where the dryer is located. If it's too cold, you get the 8.8 error. When I first had the error it was at 7:00 in the morning trying to dry some clothes that were in the washing machine overnight. I couldn't get the dryer to work and had to go out for a few hours. When I got back around 11:00, the dryer worked fine. The only difference I could think of was that it was warmer than before. So a few weeks later I rememberd this and tried to test my theory. I waited for a very cold morning and tried the dryer and got the 8.8 error. Then I took a small patio table heater and turned it on in front of the dryer for about 20 minutes. The dryer fired up right away. I've used the same routine whenever I get the 8.8 error and it's always solved the problem for me. Hope this helps
Dec 11, 2008 | Maytag Neptune MDE5500AY Electric Dryer
HP Media center 1170m
did you checked the ram just clean and fix it again. bye
Oct 01, 2007 | HP Media Center m1170n Photosmart PC...
Whirlpool LER4634J Electric Dryer Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
