Question about Passport 8500 Radar Detector
Passport 8500 will no longer switch to LOUD mode
All of a sudden my Passport will not alert in LOUD mode. I've swiched the menu, and even set it back to factory settings then swiched to LOUD, and nothing. With the volume all the way up, it is still very quiet.
  • 134 Answers
Try doing a factory reset as described in the user manual since it is possible that a power fluctuation has somewhat corrupted the internally saved user settings.
Posted on Mar 17, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
The alert is to loud, how can I turn down the volume for the alert?
Press the WEATHER/SNOOZE button to turn on the weather radio. Then press the "UP" or
"DOWN" volume button to select desired listening level. (Note: Turning the volume all the way
down [where no bars show] puts the radio into silent mode.)
Hope that helps resolve the issue.
Regards
Anand
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
DVD disk jammed in Salora TV+DVD, DVD mode unavailable
press source buttton ( at hhe remote)
then enter 2 5 8 0
then dvd set on.
Apr 03, 2010 | Televison & Video
Put Escort passport 8500 X50 into calibration mode.
If you hold down the mute button (on front) and the two buttons on top...when you power up, it will reset.
Mar 20, 2009 | Passport 8500 X50 Radar Detector
My passport 8500 stays on Full Alert
First you should try it in another car if possible. It sounds like an electrical problem. You need to rule out if its the car or the radar detector.
Open the end of the power cord it unscrews, check the fuse in it to see if its blown.
Ive also seen the screws loose that hold the circuit board down cause problems. If its out of warranty now, there should be a screw on the bottom usually under a sticker. If you peel that back and remove the screw, and lift the bottom off..Tighten any screw you see holding tbe board down, dont tighten it to hard. Then replace the cover.
Post back after you try some of those, let me know if it still does it.
Mar 18, 2009 | Passport 8500 Radar Detector
8500 Alerts for no aparent reason
Got to the bottom of my false alarming situation. I finally called Escort and discussed the behavior with the technician who immediately concluded the antenna was failling and needed a repair. $30 worth of shipping and about a week later I got my repaired unit back and it works perfectly. Not sure the root cause but I am going to treat it as gently as possible and hope it keeps working, I sure like it better than the V1.
Dec 05, 2007 | Passport 8500 Radar Detector
Continuous alert
About the only thing to try with the Escort 8500 and the x50 is to do a full reset. Hold all 3 buttons down while turning the detector on. I believe Escort will still work on it, there will just be a service charge with no warranty.
Sep 14, 2007 | Passport 8500 Radar Detector
Passport 8500 Radar Detector Logo
155 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
