Question about Herbeau Creations HERBEAU "Luberon" Art Nouveau Fireclay Double Sink - 4615-30 - French Ivory
I have a brown colored stain in the bottom of my white franke white fireclay sink (maybe coffee stain, not sure) I can't get it clean with regular hand soap which is what franke told me to clean the sink with. Also, I have a small aluminum scratch mark, they told me to use baking soda, hardly cleaned it, just barely took some of the scratch mark away. Does anyone know what I can use to clean either of these stains. My sink is brand new, only 3 months old and I'm worried. Thank you, Annie
I used Cerama Bryte for the dark colored stain, I left it on for about 5 minutes and then rubbed it clean, the stain is gone. Now I tried it on the small aluminum scratch marks, no thank you, it couldn't help that problem. Still seeking a solution. Thanks
Posted on Mar 03, 2009
How to clean coffee stains on white coffee maker
Plastic can absorb Stains, so you will need to use some kind of bleaching poduct.
some products you can try individually:
  • Baking soda
  • Bleach
  • Water
  • Vinegar
  • Rubbing alcohol
Dilute with luke warm water , except for Rubbing Alcohol
Use some kind of tray which you don't mind if it gets bleach stains to protect your countertop. put the device on the tray.
If you can't soak an item, try disconnecting the device, then wrapping a lightly soaked hand towel or paper towel over the area that is discolored
Rinse with luke warm water, and make sure device has completely dried before reconnecting.
Aug 03, 2016 | Cuisinart DCC Coffee Makers & Espresso...
I have a white rubber sink mat. How do I clean off the coffee and tomato sauce stains?
I tend to scrub my mat with detergent. Rinse it with warm water and leave it to dry off. You can also leave them to soak overnight with soap and then rinse them off in the morning. For really tough stains, I pour baking soda on top, let it sit for a bit and then scrub the mat. You can try leaving them in the sun, because sun bleaches white things.
Jan 10, 2013 | Home
Even on the Pots and Pans setting, there is still food encrusted onto plates and silverware. Worst of all, my coffee cups are getting more and more stained. Sometimes even the lipstick marks on the rims...
There is a plastic cover on top of the drain. If you depress the two tabs on each side of the sprayer arms(bottom) and lift of sprayer bars. Reach dow and the plastic filter lifts right off. Many times this get clogged with debris. Also be sure and check that the drain hose has not fallen to the bottom of the sink cabinet. The hose must be above the garbage disposal and the hose runs into the disposal from there. Most times if you look under the kitchen sink and to the wall, u will see a nail or screw that the hose should be tied to. Hope it helps...
Apr 19, 2017 | Miele 18 in. G601SC Plus Slim-Line...
Can I drop-on this sink? or only undermount it? Thanks, Brooke
You are only restricted to undermounting these sinks because of there depth in relation to the siting of the tap, that's all. Remember if you place this sink on top you willhave to discreetly raise the tapbase fixing to maintain easy use of the taps
Jul 15, 2011 | Franke MHK-720-31-MB Fireclay Double Bowl...
Difference between black basket strainer 900 and regular strainer.also i want white. are there different sizes or universal.
Unless you have a special purpose sink all basket strainers are standard size. You should be able to use strainer from any manufacturer that has the color that you want. If you are doing this yourself make sure you use rubber gasket and fiber friction ring. These go on the underside of sink in between sink bottom and retaing nut. I would recommend you use a small amount of pure silicone caulking in between flange of strainer and sink surface. Be ready to wipe off excess caulking as soon as you get retaing nut snug as it starts to cure in about ten mins. I use paper towels and wipe till its clean. Hope this helps. Thanks
Nov 16, 2010 | Franke 900 Black Basket Strainer 900
I have a white Franke fireclay sink. We also have very hard water despite using an undersink filter. The sink is part of a new remodel and despite little use so far and lots of wiping, the water spots seem...
The best product I have found to remove water spots is a product called A-maz water stain remover in a 14 oz tub. There is no magic "wipe on,wipe off" product that I have found. Initially it is a little labor intensive but this is amazing stuff and can return your sink to its original luster.
This company also make a sealer but I have not tried it. A couple of alternatives might be Rain-X or Maguires auto wax. The concept here is to put a barrier down that will seal the pores of the sink and make it easier next time to remove the spots. My favorite is Maguires about every 3 months. I have provided a link below to the A-maz web site where you can find a distributor nearest you.
May 10, 2010 | Franke Double Undermount Fireclay Sink -...
The bottom of my stone sink is dicoloured it was blue and after ive cleaned it to get the stain out it drys white
There is an exposure, usually the coating maybe has worn off, so it exposes the sink. Try a re coating :)
Mar 29, 2010 | Home
What product to clean a franke sink
Stainless Steel use softscrub on Granite you can use soft scrub or vinegar
Oct 21, 2009 | Franke Home
I Have a FRANKE Fireclay white Farm sink only 90
E-mail the manufacturer from this page.
Sep 04, 2009 | Franke Plumbing
Herbeau Creations HERBEAU "Luberon" Art Nouveau Fireclay Double Sink - 4615-30 - French Ivory Logo
268 people viewed this question
Top Herbeau Creations Plumbing Experts
Paul Carew
Tom Chichester
Are you a Herbeau Creations Plumbing Expert? Answer questions, earn points and help others
