Question about Loewe Articos 55 55" Rear Projection Television
Dlp bulb bulb looks in tact except for a small cloudedspot in the dead center, is the bulb still operational or is it bad
  • Loewe Master
  • 5,138 Answers
Its Bad if it does not Light! Call Encompass Parts or look up their website for listings of Parts to your TV.
1-800-638-3328 also I have found some good deals on Lamps on E-Bay got one for mine for 85.00 and got my Ballast Board for 65.00
Posted on Nov 14, 2009
Phililips 50 dlp does nothing but the sound. then the red light comes on. changed the bulb but it does the same thing. what is the next step.
Hello, it sounds like one of the cooling fans has stopped in it, sometimes the get clogged up with dust so bad they can't turn causing the set to go into shutdown or a fan has gone bad. try cleaning the fans, bur DO NOT USE CANNED OR COMPRESSED AIR!, use a vacuum and a small paint brush to clean them out. The other thing is listen for a squealing sound, if the color wheel is going bad the usually squeal a bit, but if the picture is normal looking for the time it's on, that shouldn't be the problem.....tks
Sep 14, 2014 | Philips 50PL9126D/37B 50" DLP TV
It maybe a filter problem go through the steps you took when installing the new bulb and check all then test.
Thanks J
Feb 03, 2008 | Toshiba TLP S30 Multimedia Projector
Dark Band on Samsung projection TV
most likely optical engine issue----bad light engine.
Aug 27, 2012 | Samsung BP96-01073A E-Series Replacement...
Infocus IN24 Projector has large Dark Grey/Black Spot in the middle of the image.Lamp has 600 hours,Installed my spare "NEW" Lamp,still the same,Bulb makes no difference.Was watching a movie...
There is a lens(looks like a small magnifying glass) made out of plastic that the light shines through to focus the light on the mirror before it hits the DLP chip, that lens is Melted in the center. I unfortunately had the same thing happen to me, and I am unable to find a replacement part.
Jan 16, 2011 | InFocus Work Big IN24 DLP Projector
Brakes Lights dont work on a 2006 Chevy Silverado
I've worked on these the first drove me crazy. its the turn signal switch every thing runs thru these. head lights, turn signal, brakes. except the third brake light. it runs directly from the brake switch. go figuare
Jun 22, 2010 | 2003 Chevrolet Tahoe
Hi I have a jvc dlp hdtv that uses a Bulb jvc CL110u11AA. I understand that if the Tv is going dark that I should replace the Bulb. My Tv is also going Green most images are greener that normal. Is this...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Samsung DLP HL-R5667W, seeing little boxes of static flashing
samsung color weel replacments are all the new air bearing type insted of fluid type. if you replace the new color weel , color will look bad. also note when ordering your replacment make shure it comes from samsung and not just a generic model.
the original replacement will come with a set of instroction to reset the dmv ajustments.
find the dmd pcb and look for a2 jumper that is visable through a small squaire remove the jumper. then folow instrustions with new color weel.
hope this helps.
regards,
daniel.
Jan 13, 2009 | Samsung DLP HL-P5663W 56" TV
The REAR turn signals & most of the brake lights (except for the small light on top) on my 2000 contour svt are not working. Why would this be happening?
check the fuses and absolutely make sure the correct bulbs are installed. some bulbs look alike, but don't act alike. hope it helps
Sep 12, 2008 | 1996 Ford Contour
Mitsubishi 52 " model WD-52631
Nope the bulb is fine. This set sucks up dust and contaminates the light engine. Rarley does blowing the set out with compressed air fix this, The light engine can be disassembled and cleaned but this is best left to someone who has done this once before. Because if it gets messed up you get to buy a $1500.00 light engine
Feb 13, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Loewe Articos 55 55" Rear Projection Television Logo
Top Loewe Televison & Video Experts
Jerry Umali
Grantec 2000
Level 1 Expert
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
