Question about Health & Beauty
My homedics back massager with heat, stop working all of sudden, does it needs battery even though it has an electric cord.
  • Anonymous Mar 07, 2009
    I have the same problem. No, there arn't bateries. I am still trying to fix mine.
The back massager with heat stopped working, bought a new power cord, still does not work, must be something in the back massager, but what to do ? ken
Posted on Apr 10, 2009
I was given a homedics percussion action handheld massager with heat. It won't work at all. It does nothing!
Check that you have power and that there is a lit LED when a massage attachement is put into the top. Otherwise check this link for further instructions and power issues.
The 3 Best Handheld Percussion Back Massagers Under 50 Back Pain Relief...
http://back-pain-relief-products.net/handheld-percussion-back-massagers/
Feb 09, 2015 | Homedics Health & Beauty
The electric cord on my hand held percussion HoMedic Masager is loose. How can I open it and fix it?
What is the model of your HoMedic Massager?
If it has a rubber grip on the handle, you can take it off by simply sliding it towards the power cord, with effort and a little patience.
Once the rubber grips are off, you will find 1 screw hidden under the grip, 1 screw near the power cord, and 5 screws on the head, take all the screws off.
Once you've unscrewed all of the screws, unscrew the 2 vibrating heads then take the unit apart.
Good luck.
Jul 22, 2014 | Homedics Health & Beauty
I'm having a problem with my Homedics SBM 300H Massager. I was using it when it suddenly stopped, after hearing a faint "pop" sound from it. I tried re-plugging it in another outlet but still no...
Yes there was a short circuit and am sure the massager and the cpomputer where plugged in the sane extension box that was why there was loss of power when the massager stopped working.For the massager it is the fuse so get a new fuse for it.
Jan 21, 2011 | Homedics SBM 300H Therapist Select Shiatsu...
How to replace power cord om homedics massager
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Jun 20, 2009 | Homedics Inc Massager Neck Massager W/heat
Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Feb 23, 2009 | Homedics PA-4H Programmable Percussion...
Homedics programmable percussion massager with heat
The motor is Jammed
Try Taping it or banging it lightly
if that don't work im sorry ether needs repair or buy a new one
Regards; Aaron
Sep 15, 2008 | Homedics 10 Motor Back Massager with Heat
Back Massager tips
Avoid rough or sudden movements as you cover and uncover the different areas of the body.Make sure you place the towel gently and avoid abrupt movements that might be disturbing to someone in a relaxed state.
Aug 27, 2008 | Homedics 10 Motor Back Massager with Heat
Health & Beauty Logo
2,127 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
