Question about GE Nautilus 24" Built-in Dishwasher
I have a GE Nautilus dishwasher GSD2230F01WW is it hooked into the hot water under the sink or the cold ?
  • 170 Answers
It should definitely be hooked into the hot water...and the temp of the hot water should be around 120degrees and not to exceed 150 degrees as dish damage can occur. There is a heat assist in the DW that helps to heat the water temp also.
I hope this helps....good luck and good day...thank you for rating my effort....The Fang.
Posted on Mar 28, 2009
How to hook up
Yes it only uses hot water. There should be a 3/8 fitting to hook up a water line. The drain hose connects to the air gap on the sink and when hooking up the power if there is no power cord be sure to hook up the black to black, white to white, and green to the green or bare wire.
Feb 12, 2014 | GE Nautilus 24" Built-in Dishwasher
My dishwasher won't drain
There are probably two valves under your sink that control hot/cold water they maybe turned off. Or the hoses are kinked
May 30, 2010 | GE Nautilus 24" Built-in Dishwasher
I just got this used and would like to know do you hook it to hot water or cold when installing it?
Hello. Definitely hook it up to the hot water under the sink with a shutoff valve. Then when using it always run the water in the sink until it is hot before you start the dish washer.
Mar 13, 2010 | GE Nautilus 24" Built-in Dishwasher
My GE Nautilus dishwasher takes water in and then stops and nothing happens. I tried flusing it with hot water and vinegar and no progress. Any ideas are very welcomed. Thank you.
Flushing the hose with hot water and vinegar would not help.
If the machine is filling and then stops, parts that may be responsible are the impeller pump and the control board.
If the machine is under filling, test also the floater switch.
If the water is not warm, check the heating system or the hot water supply.
If this machine has dual inlet, test that both solenoids are opening.
Dec 02, 2009 | GE Dishwashers
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
How do i drain my ge nautilus dishwaher
Pour hot water into the bottom and force the timer to drain cycle. Keep doing this until the suds are gone.
Aug 18, 2009 | Dishwashers
Not getting hot water to my dishwasher
Assuming that you dishwasher is connected to the same under sink hot water valve as your kitchen sink and that you run water in your sink until hot water really does arrive in the sink just before you start your dishwasher, your problem is probably a failed heating element inside your dishwasher. The other symptom of this heater element is cloudy film on your glassware after the cycle completes.
If the above is true, then replacing the element would be your next step.
Aug 11, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher SSD3900J00ww wash water cool heating element hot on
Crew that installed new cabinets and sink hooked dishwasher to cold water line I switch it works fine now. Thanks Don
Mar 20, 2009 | GE Dishwashers
GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Mar 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus dishwasher
Check inlet valves as if you have 2, it may fill using 2 inlets (hot & cold) but only rinse on using 1 ((cold only). So if the cold inlet is faulty, then you will only notice on the rinse. If thats not it then chances are it is the controller unit. regards
Jul 22, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
137 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
