Question about SanDisk 2GB microSD Memory Card
Scandisk formatting my scandisk memory card for my camera wont format...please help??
  • Anonymous Mar 16, 2014
    how to get pictures off of damaged scandisk memory card
  • 423 Answers
Hi there and welcome to Fixya.
You have to format it in the camera. So double check your menu. Not sure what camera you have, but there is usually what's called a low level format. It's found in the Setup menu. Turn the camera off, pull the card out, remove the batteries. Wait 5 minutes, then reinsert the batteries and the card. Turn on the camera and look for low level format in the Setup menu. That should work, and thanks for coming to FixYa. Let me know if you have any other problems.
Rob
Posted on Mar 04, 2009
    Master:
  • 404 Answers
Use a pc to format it instead.
Posted on Mar 03, 2009
Formatted scandisk in casio camera
Unfortunately, yes. That is why we always advice to back up all data before proceeding with the format.
Jun 16, 2010 | SanDisk 1GB microSD Memory Card
Scandisk memory card keeps saying error
Some cameras will not work with the larger flash cards. Also the SDHC requires an adapter that accepts the high density. Many built into the computers do not accept the high density and will demand they be formatted. Verify the requirements of the devices you have for compatibility.
Apr 27, 2010 | SanDisk 4GB microSDHC Memory Card
Filesys error e00100 when attempting to format a Scandisk 2.0 gb memory card.
Hi ,Welcome
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 02, 2009 | Kodak EasyShare CD33 Digital Camera
    Foramtting scandisk
    If this memory card will be connected to a camera you can simply put the memory card to the camera and there you can format it using the camera's menu, you can also format this memory card using a card reader that will be connected to your computer, just put the memory to a card reader then connect it to the computer that way you can also format the memory card....
    Dec 29, 2008 | SanDisk 2GB microSD Memory Card
    How do i format my scandisk
    If you are only using the card in a PC then when you plug the card into pc,it shows as a drive under my computer,you rt on the drive and pick format, fat.
    If you are using a sd card for anything else such as a phone, you format the card with the phone,or whatever devise it is being used in, and you DO NOT format the card with the PC.
    Error 30
    The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
    Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
    Error 30
    Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
    Error 30
    Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
    Error 30
    Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
    Error 30
    The "E30" error code is displayed when reading/writing data on a CF card has failed. Especially, the error code "E30" may appears when you tried to remove a CF card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the CF card with your camera Try to format the CF card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a CF card will erase all data on the card. Once the CF card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the CF card.
    Aug 29, 2005 | Canon PowerShot A310 Digital Camera
    SanDisk 2GB microSD Memory Card Logo
    175 people viewed this question
    Top SanDisk Electronics - Others Experts
    Brian Sullivan
    Brian Sullivan
    k24674
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
