Question about Bosch Ovens
Error code E-101 & E-115 Regulation ErroR??
We have a Bosch HBL8750UC & it comes up with this error. Any ideas?
THX Johan
I have a bosch oven with an error code of E0511 can you tell me what it means
Did you google for the code or go to web site to find out just what it stands for? Once you have an idea of what the issue might be you can start doing your thing to fix it.
Sep 13, 2017 | Bosch Ovens
Common heating faults with Bosch HBL8750UC double oven
For all Free appliance repair videos visit our VIDEOTUTORIALS 1, If the Bosch fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the BOSCH element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your BOSCH fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL8750UC Electric Double Oven
Bosch oven error code F43; breaker reset doesn't work. Door ok (though it locked while using broiler). Beeps continuously. Worth fixing? OK to use gas burners without power? Smells very gassy.
Don't use any appliance that smells of gas or partially burnt gas. Time for a new one or a professional Bosch service engineer. Your call?
Here is the Error Code
F43Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  1. Check P24 connector on the power board.
  2. Ensure door latch switches are operating properly.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis.
  5. If F43 persists, replace power board.
Read more:
Bosch Fault Codes AppliancePartsPros com
Dec 20, 2016 | Bosch Ovens
Why won't it heat up? And what does error code 311 mean
rcr311w codes Washing Machines Questions & Answers ... > Forum > Tags > rcr311w codes
Zita here is one link to error .
Sep 12, 2015 | Bosch HBL5450UC Electric Single Oven
Hbl8450 E118 error
E118 indicates a comma error. You could check for loose connector block or plug on ribbon cable. Best course of action is to call a Service Engineer.
Sep 19, 2017 | Bosch Ovens
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
Wall oven error code
Having the same problem.
Has anyone found a solution to this problem?
Thank you
Sep 03, 2008 | Bosch HBL 745 Stainless Steel Electric...
Bosch oven HBT346 - how do I reset the clock?
Hi after a power cut my Bosch cooker clock is flashing but I cannot reset it as have no instructions - any ideas? Thx
Apr 15, 2008 | Bosch HBN 442 / HBN446 Electric Single...
Should I buy this product?
its hard to say its a turky shoot now days look for best warrenty ease of service and do stuff like search the web for customer complaints on the models you want to buy most of internal parts are made by same contractors and mfgs are just assembly plantslike kenmore is made by whirlpool but serviced by sears whirlpool svc better etc
Dec 28, 2007 | Bosch HBL8750UC Electric Double Oven
Ovens Logo
705 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
