Question about KitchenAid KESC307 Electric Kitchen Range
Knobs on front of stove. These turn on if leaned against.
I have a kitchen aid stove with the knobs on the front. They are positioned so that if you inadvertantly lean on them, the burner turns on. Most of the time we don't notice the burner is on until it is bright red or something starts burning. Is there any device that we can put on these knobs to keep them from turning on when leaned against?
  • Ron Coons
    Ron Coons May 11, 2010
    there may be a solution to your problem pleas include entire model so i can look up for you
  • 833 Answers
SOURCE: kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Posted on Dec 03, 2007
jumptrout51
  • 3361 Answers
SOURCE: gas cooktop ignitor runs when stove is off.
Defective spark switch. Could be one could be more than one.
Posted on Mar 13, 2009
  • 3 Answers
SOURCE: I need metal replacement stove knobs.
The plastic knobs melted on my new LG stove the first time I used the broiler. It is a Model LRG 30355ST. I called their service number (1-800-984-7469) and they were very sorry but I would just have to order new plastic knobs. They also advised me that I should have purchaced an extended warranty. Maybe I will just purchace another brand next time.
Posted on Dec 12, 2009
  • 949 Answers
SOURCE: Front right burner knob will not activate the sparking
You are correct, on most Kitchen Aid units the switches come as an assembly of all 4 with the wiring, I would have to have your exact model number to be sure but most often you cannot replace just the one switch.
Posted on May 07, 2010
Testimonial: "Thanks for confirming my hunch. Many thanks!"
SOURCE: We have a Kitchen Aid
It just happened to me too, just after cleaning the stove. Water apparently got into the switch (under the knob). Dried out in half day, and now is fine.
Posted on Jan 17, 2012
How do I get the igniter knobs on the stove unstuck. Impulled all the knobs off the stove front to clean under them and now the left two won't turn
Sandy, make sure knobs went back on correctly, did you push them too far past there seats, look at the 2 that work and see if the 2 not working one are pushed on further.
Feb 20, 2016 | Kitchen Ranges
Why wo't two of the knobs on my kitchaid GAS STOVE WILL NOT TURN
Take the knobs off and look inside. Compare them to the good knobs for any differences. reseat them back on and try pushing the knobs in while turning. It may be a child safety feature.
How do i light the pilot on the top of the stove
some are fitted with pilot control knobs on front of machine and some you turn the burner tap to low flame position then press it in and light pilot
Apr 24, 2010 | Vulcan 36L Gas Kitchen Range
Scrubbed the gas fixtures on stove top, won't light
this is something I do not recommend you do yourseelf, but there is a adjustment screw on the front under the panel near the knobs little screw that can be adjusted
Feb 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas ignitor
Try pulling the knobs out just a bit. sounds like one is jammed.
Dec 30, 2008 | Avanti G20AW-1 Gas Kitchen Range
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Oven vents on front are stained and ugly. How do I clean them?
sorry but you wont be able to remove the "stain" what has happend is the paint used by maytag has become discolored from the oven vent heat and the only way to correct it is to replace the panel. they are available but for about 80 bucks. you could try to paint the panel but it will do it again.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
122 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
