Need code for an insignia tv. tech did not have a solution to the problem with out purchasing new remote
026,018,072,081,049,024,000,038 are the codes to check with Insiginia brand TVs. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
SOURCE: i have a hughes hrmc-11
auto code search.
hold down the tv button and mute button until the tv button light stays on. press the channel up button(this will cycle thru codes) test with the power button. process may take a few minutes. when the tv turns of press the tv button to store code
SOURCE: how to program remote for tv and codes
dont have codes for programing HRMC-5 (11), I HAVE A SYMPHONIC tv
SOURCE: lost owners manual and need to program remote to Panasonic
HRMC 15 Code Scanning method...
1.Press TV device button on the HMRC 15
2. Press Select and Mute simultaneously until TV device button flashes.
3. TV device Button should now stay lit.
4. Aim Remote at TV
5. Press The CHANNEL button UP ...repeat until your TV turns off.
6. Press Power Button to turn TV back on (Thus confirming you found the right code).
7. Press the TV device button to lock in code.
8. ENJOY !!!
SOURCE: need codes for hughes remote model # hrmc-1
You can get the codes here for the remote. starts on chapter 8.
http://www.directv.com/learn/pdf/System_Manuals/Hughes/HNS_HIRD-E6.pdf
160 161 156 165 065 070 004 023 024
056 074 081 152 167 145
Code Entry
Use the REMOTE pane under the System Setup menu tab to program your
HRMC-11, HRMC-12, or HRMC-13 remote control to operate your TV, VCR,
SAT, AUX device, or DVD (HRMC-11 and HRMC-12 only). The AUX menu
button can be used to control a CATV box or other type of device. Use the menu
buttons to choose the desired type of device and display a brand name menu list
from which you can select the manufacturer of your device.
Code scanning
To use the Code Scanning method:
1. Repeatedly tap the top part of the CHANNEL (CH) button.
2. Continue to step through the codes until the component turns off, indicating
you have found the correct component code. If you accidentally pass a code
that responds or realize you may not have been aiming the remote control at
the component, tap the lower part of the CHANNEL (CH) button to step
backward through the codes.
3. Press the remote control POWER button to verify the proper code by
turning the device on and off.
4. Press the device button (in this example, TV) again to lock in the code.
OK
