Question about RCA EZ 105 Camcorder
Where do you put the 2mg card slot ontop is not deep enough
Small wonder 101
  • 423 Answers
If the space for your card is not deep enough, then you might have bought the wrong card. Make sure it's an SD card.
Rob
Posted on Mar 02, 2009
The spring load for the film card in my Sony DSC-W80 doesn't work anymore. Please help!!
If the card won't click in/out try and use a paperclip - slightly open and put over the card - pinch a little and pull out without any force.
The spring loading is deep inside the camera only a technician will want to open up and replace.
The only way to clean (and be very carful) is to use a cotton bud m put 1 drop of CD/ROM cleaner on the very tip (just one drop) and rub slowly along the base where the card slots in.
Some shops often sell a card holder (like a Nokia card) puller these will also have enough grip to insert or withdraw a card. - Ray
Feb 03, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
I was just wondering where to put my Graphics card in my computer :S In one of these white slots? The only number i could find on it was E210882
I depends upon the type of graphics card you have purchased. The white slots are PCI expansion slots
and if the there is a longer slot in the middle of the motherboard next to the PCI slots, then it will be a AGP expansion slot.
APG graphics card are better graphics cards and these slots are designed for these graphics cards.
Dec 20, 2010 | Dell (E210882) Motherboard
Hoe do i change my nintendo ds game slot
You must remove the bottom of the DS. There are security screws that need to be removed. It takes a special screw driver to remove them. There are also 3 or 4 regular small phillips head screws that must be removed. Then the bottom can be removed. Be careful not to break the power switch off when removing the buttom. Once the bottom is off you can see the slot and unsolder it. You will need really good desoldering and soldering skills and the pins that will need to be removed and resoldered are small. You'll need a very small tipped solering iron. You won't find one small enough at radioshack. You'll have to order one special from a store online. Once you have the new slot put in you then just put it all back together in reverse.
Feb 06, 2010 | Nintendo DS Lite
I don't now how to make the PC card slot at a hp compaq nc4010 to work.can you help?
At the back portion of your PC, there is a compartment small enough to insert your PC card. IF you can open it, you can probably check the slot if its not full. Usually, PC card slot is only good for two cards. That is also true with memory slots except HDD slot :-)
Blessings.
Dec 12, 2009 | HP Compaq nc4010 Notebook
What size of MEmory Card does the Samsung SC-D103 use?
it would not matter the size memory card. What matters is how much you want to be able to store on it. I would recommend nothing smaller than and 8 or 16MB memory card. you can put as little as a 2mg or even smaller but you won't be able to save much at all to that.
Oct 16, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
PS2 STATES THAT MEMORY CARD IS NOT IN SLOT, BUT IT IS.
THis is simple. Either your memory card has not enough room, the memory card is broken or the slot you are putting it in is broken. Try putting it in the other slot.
May 24, 2009 | THQ Video Game Consoles & Games
Trying to locate where to put a memory card
Hello, was wondering if you meant memory card or memory chip. If it is a chip, it goes next to the other memory chip in the slot. Must be right memory or the motherboard may fry out.
If it is a memory card, you must have SD-MS slot. If you do not have the slot, you can by one and hook it up to the pci slot.
May 22, 2009 | Compaq Presario 5000 PC Desktop
The 2mg card does not fit in slot to long
Hi there. It means you have the wrong card. Go get yourself a 2gb SD card.
Rob
Mar 02, 2009 | RCA EZ 105 Camcorder
No problem
I can't find any decent photos of your laptop online so I can't see what you're seeing, but it may be one of several things:
1) A PCMCIA or Express Card slot - this is a flat, long slot that usually has a dummy plastic "card" in it. You put wifi, network, sound, modem, video capture etc. cards in here
2) A smartcard reader - often located just under an express card slot - is a very thin slot where you put a business-card like ID card which can authenticate you, like a fingerprint. When you take it out your computer locks automatically. These are a defunct security standard usually on business laptops, not used much anymore but it's so small that a lot of laptops come with them anyway. In fact it's easy to not even realize it's there.
3) A proprietary expansion slot - HP in particular are known for putting special "expansion ports" just for HP devices. Perhaps this laptop is the same.
I'd bet it's probably #1.
Dec 24, 2008 | Gateway Computers & Internet
RCA small wonder EZ 101 won't power up
I found that the RCA Small Wonder is very touchy when it comes to batteries. My unit went out 2x on me and I almost there it out. First time for no reason except I tried to put videos on computer. 2nd time I put rechargable batteries that I asume we're to powerful for the unit. I let it sit for a while and put regular AcDelco batteries in it and it was fine.
Jul 25, 2008 | RCA EZ 105 Camcorder
RCA EZ 105 Camcorder Logo
126 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
