Question about Toshiba DR410 DVD Recorder
Recording TV programs on DVD Recorder
How can I set up Channels on my DVD Recorder from TOSHIBA, Model
D-R410KU (Model is from 2008) in order to record from MAGNAVOX TV
Model 32MF338B LCD TV to my TOSHIBA DVD RECORDER?
  • cguerra636 Mar 04, 2009
    I can record the satillate but I can not record antenna channels off my sony bravia hdtv? Why
    President:
  • 1,285 Answers
If you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Posted on May 27, 2009
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
I own a Toshiba DR420KU player/ recorder. I can't make it record premium programs. It says it's a CPRM device and that it will record onetime only broadcast since it's copywright protected. I found on the...
Even if you have the correct disk and the correct setting in the recorder, if the CPRM tag in the broadcasted program is set to deny all recording then your recorder will not record it. Sadly but it's just that simple.
Aug 28, 2010 | Televison & Video
Won't allow recording ESPN and other cable channels.
It sounds like the programs are copy protected. I've had the problem with an E 27 error, but I've had success with recording other programming.
Jun 14, 2010 | Toshiba DR420 DVD Recorder
What is the setup code for the DVD Video Recorder D-R410KU to control the player with the cable box remote?
I have found the code for the Toshiba D-R410 DVD recorder ! The code that works with my Radio Shack family 5 in 1 remote is:
1008
I hope this helps !
Feb 06, 2010 | Toshiba DR410 DVD Recorder
I GET TO THE WINDOW TO PROGRAM A RECORDING BUT FOR CHANNEL SELECTION I ONLY GET L- L-2 OR L3 I NEED TO BE ABLE TO SELECT THE CHANNEL LIKE 6 THIS IS A NEW HD TV. I AM ABLE TO PLAY EXISTING SHOW ON THE DVD...
Hi.
You will need to connect an antenna and program channels to internal tuner if you want to use the built in tuner.
It is not clear if your problem is with the HDTV or with the DVD recorder.
Both have an internal tuner, and both can tune channels , L2 and L3 are the input lines used when you connect for example to an external receiver.
Regards.
Nov 14, 2009 | Panasonic DMR-E80H DVD Recorder
Programming TV-channels on old Samsung VHS video recorder VB-520T
I tried another position of te range switches and scanned again and again and then I found the tv channels finally.
Mar 25, 2009 | Televison & Video
How do I record a TV Program.
Video & Left,Right audio go out of Comcast cable box to L1 input on DVD recorder,Video & Left,Right audio go out of DVD recorder to a line input of your TV.  Record L1 input on DVD recorder.
Jan 10, 2009 | Panasonic DMR-E80H DVD Recorder
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
Oct 14, 2008 | GoVideo DVR4300 DVD Player/VCR
Toshiba D-R410KU DVD recorder, How do I set it up with a regular TV and no cable box? I want to record regular TV shows and I receive only local station via Rabbit ears .
No offense intended, but...get a life and a new TV and a cable box with DVR...pre-record your shows and later record on Toshiba DVD recorder using HDMI cable, available at Fry's for $10. Also, you might still be able to do what you want if you are willing to read every word of every page of the user manual...been there done that...it wouldn't work for me either until I did same...I know, only read the user manual as a last resort, so...
Oct 08, 2008 | Televison & Video
Toshiba DR410 DVD Recorder Logo
565 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
