Question about Sony PlayStation 3 40GB System
The playstation three is turing on, but it isnt sending anything to the tv and the control isn't connecting to it.
  • 2 more comments
  • evanworks7 Mar 02, 2009
    When you mean off, are saying when the power signal is red or completly off. And as for the power button, from the front or back?
    Update: i'm pretty sure i just did the manuel reset but but still the tv is blank and the control are not reading the system.
    More info: the ps3 is 14 months old, didn't not have any problem previously and have not installed any updates resecently. it was working sunday morning, but that afternoon this problem occured
  • Anonymous Mar 03, 2009
    errm i have the exact same problem ?
    how did u fix it ?
    i'm in the mood to chuck it out the window :@
  • daniel_hasse Apr 09, 2009
    what does it mean when it says the hard disk must be formatted and how do i do it?? also my system wont read my controlls
  • 2,653 Answers
First thing to try is a manual video reset.
While the PS3 is off.
Hold down the power button until you hear the second beep, quickly release.
Let me know if this solves your problem and we'll proceed from there.
Posted on Mar 02, 2009
  • RescueTechLA
    RescueTechLA Mar 02, 2009
    Allright well Sony says to try different cables, tv, etc. but I've never seen that fix the problem.
    You could also try booting without the hard drive to see if you get any kind of change, but it's not likely.
    Majority of the time it's the Video Processing Unit on your machine that is to blame.
    It's a similar to the xbox RROD problem.
    Basically the unit gets too hot and over time the RSX (video) losses contact with the motherboard.
    Problem with the PS3's is there is no easy method to fix it like the xbox.
    Sony will probably be the only ones who can address it.
    Hope this helps.
Why wont it connect?
there is a sync button somewhere on the controller and the usb thing you plug into your Ps3, pres those at the same time continuosly put make a 2 second break untill it connects.
May 16, 2013 | PDP Afterglow AP.2 Wireless Controller for...
I'm guessing the issue is that the PS3 isn't responding to your controller input.
Ensure that the PS3 controller is actually on. You can turn on the controller by pressing the Playstation button in the center of the controller. There will be a red light on top of the controller indicating that it is on.
If no light shows up, it's possible that the controller simply has dead batteries. Grab your controller charge cable (should have been included with controller, looks like this) and connect the controller to the PS3 while the console is on. Give it a few minutes, then press the center Playstation button again and see if it responds.
It's also possible that the controller just isn't synced to your PS3. Again, grab the charge cable and connect it to your PS3 while it's on. Then press the Playstation button while the controller is connected. It should sync it to the PS3.
If none of that is working for you, there may be an issue with the controller itself. The easiest fix it to reset the controller. There should be a tiny button in a hole on the back of the controller. Just press it (you'll need a paperclip or something to do it) and the controller will reset. I believe you'll have to re-sync the controller (using the cable again).
You should also try syncing other controllers to your PS3 to make sure that the issue isn't with the PS3 itself (which would be awful; I've never heard a PS3 breaking like that but I suppose there is always a first). If other controllers work then either your controller's battery is dead or the controller is actually broken. I don't think Sony repairs/replaces controllers so you may have to buy a new one.
It may be worthwhile to checkout their support page first, to see if anything helps before shelling out 50$ for a controller:
Sony Support
Sony Repair
Amazon - PS3 Controllers (I recommend Silver; it's ****).
Hope it all works out!
Sep 01, 2011 | Sony Playstation 3 (PS3) Console
Can't get a picture the power is on but no picture
Try turning the power off using the switch on the back of the playstaion and turing it back on. I believe your problem is that it is not sending out the right tv format for your tv.
Oct 21, 2010 | Sony Playstation 3 (PS3) Console
Icame home and tried turning on the tv and it isnt
See black light at the back.
If no back light, problem most likely come from power supply.
If has back light, need tech to check and figure out exact problem.
Aug 18, 2009 | Akai LCT2715 27 in. LCD Television
Turing left is very hard and turing right isnt. is the powersteering broken?
you have internal problem with the rack and pinion assembly ,needs new r&p installed they mainly come remanufactured ,not cheap! good luck
May 06, 2009 | 2000 Chrysler Concorde
Not connecting to tv
If you changed the video output settings when you connected to another tv then you will have to reset it.Switch the ps3 on and hold the power button until it has beeped three times(not including the first power on beep).This should open a menu,choose option 2,this will revert your system back to default settings.Hope this helps
Mar 22, 2009 | Sony Playstation 3 (PS3) Console
Cant find channel for playstation 2
I have got a Finlux plasma television and i cant find my instructions. I have just been given a play station 2 and i have put it all correct in my television but its not coming up on my screen. I dont know what channel to put it on, please can you help me!?
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
HDMI connection
Check ur video input on ur tv dude,make sure it says hdmi in yop corner,and not svideo or anything else but hdmi
Aug 27, 2007 | Sony Playstation 3 (PS3) Console
Open Questions:
Sony PlayStation 3 40GB System Logo
109 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
