Question about Samsung AW1893L Air Conditioner
Samsung split air conditinor as18wadtl not working
I have a samsung split air conditinor as18wadtl.
it was working fine all along. but for the couple of days it does not respond at all.
the voltage stabilizer is fine and says there is enough eletric power to start off.
but the air conditioner does not display the front panel indicators which used to work earlier.
the machine behaves as if no power is available for it.
is there anyway to fix this?
  • Ken Bledsoe May 11, 2010
    There is always a way to fix something. Do you have a volt meter? We can run couple of test.
bobotfel
  • 236 Answers
SOURCE: Samsung split system air conditioner model as24bpa
Suction-5/8"
Liq. line-1/4"
Max pipe length-50'
Max vertical hight bet. accu and fcu-25'
Posted on Jan 11, 2008
  • 5 Answers
SOURCE: Split AC install
1. mind it - its a very simple installation
2. connect suction (or big cu. dia tube) connection to cond. unit (outdoor unit) big valve.
3. same way - liquid conn.(less dia tube) to small valve (liquid valve) in outdoor unit.
tight flare nut properly
4 provide power to indoor & run the same wire to cond. unit , you must hv got the ins. kit with wires and cu. tubes.
5. or read wiring diagram given of units for wire.
connect as per wiring dig. provided.
ravi
Posted on Feb 01, 2008
  • 143 Answers
SOURCE: split system Samsung AC not cooling
The compressor is not compressing. Either the compressor isn't running or the freon has escaped.
Posted on Jul 27, 2008
  • 1230 Answers
SOURCE: i have samsung split type room air conditioner,
http://aircon.ru/pbc_download/files/f1215245089.pdf
check out this web site as it has your items manual. It may help you trouble shoot what's going on. There is a trouble shooting section.
Hope this helps.
Posted on Feb 03, 2010
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
I have a samsung split system it's just shows error 6 and dosen't work .. It's the perpendicular style.. Please answer my question ...
Fault code. 6. From what I have read 1 of 2 items. The unit has completely lost freon charge. Or 2, outdoor has overheating problem, ie. condenser fan motor not running
Aug 01, 2013 | Heating & Cooling
Samsung 2.0TR split ac compressor getting heated up and tripped after running for 10 mins
High limit switch set to high, obstruction in the system, or your compressor may be wearing out.
Apr 12, 2013 | Heating & Cooling
Have a LG Split -can't get it to heat. Air conditioner works fine, when I set the remote to heat all that happens is the blower works.
If it does not start heating after a couple of mins check change over valve and coil located in condensing unit if it's stuck on cooling sometimes you can tap it to free it but if it is sticking it will need replaced
Nov 23, 2011 | LG Heating & Cooling
LG split AC LST243H-2 not working at all,failed while on
i want purchase a split ac 1.5 ton our temperature may month 45 to 46 C which brand Ac purchse
Dec 29, 2009 | LG Heating & Cooling
SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
Sep 02, 2009 | Samsung Heating & Cooling
Samsung AW1893L Air Conditioner Logo
157 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
