Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag washer/hot and cold water
When ever you set it on hot and cold it works the opposite on some settings and other settings it works the way it should work.I checked the hot and cold hoses and everything is right.
Some whirlpool washers have had A similar problem. They had a intermittent water temperature switch issue. Sometimes they put hot water in when cold was selected. This is probably the same problem as yours. I would replace the water temp switch.
Posted on Mar 25, 2009
The water temp is opposite of the setting sometimes.such as the hot is cold and the cold is hot or warm
Has it been worked on ?
Sounds like the solenoid valve controller wires have been switched.
Jul 17, 2011 | Maytag MTW5700TQ Top Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Washer was working fine! Moved washer to new house, and now it will run but only with hot water. put washer on Auto controll, and cold cold or warm cold setting, and it wont even turn on.
Have you tried checking your cold water supply faucet? Are you sure there is cold water running out of that faucet before you hooked up the hose? Is it possible there is a shut off on the supply valve that isn't turned on? Therefore it will not run on cold water setting? This actually happened to me once. We went away for a week and turned the water off for the hot and cold supplys. Came back to do laundry and only turned the hot one on and not the cold. Good luck!
Aug 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Aug 10, 2009 | Maytag Performa PAV2200
Warm water temp Maytag PAV1000aww washer
Perhaps you need to simply open the hot and cold water faucets all the way.
Jan 05, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Jan 13, 2007 | Maytag MAV3905EWW 13 Cycle Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
