Question about Canon imageRUNNER 3300 All-In-One Laser Printer
IR3320 HDD = IR3300HDD ?
My HDD on IR3320 defective
I have a good HDD on IR3300
Can I replace put it on ?
  • faxcharlie Mar 18, 2009
    I replace it with a good IR3320 HDD
    Its works good now
    Thanks for your help
Can some one guide me on how to get the system software for my Ir 3300 photocopier
Posted on May 05, 2010
No. The system software for a 3320 is different from that of a 3300.
Now if you have the system software for the 3300 and the utilities and know how to load it,, then yes, the hard drive itself is compatible.
If you have a hard drive you can use, and no ability to load system software, then call a technician and tell them you have a harddrive and you need system software loaded.
Posted on Mar 12, 2009
When the Canon IR 3300 switchs on it displays the Error code E000602-0003 please help me what to do
This error belongs to the Hard disk of the copier. Please re-install the system software in HDD or replace the HDD with new one.
Oct 08, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Can you give me ir 3300 image of hdd
this website may help http://www.copytechnet.com/forums/canon/39041-ir3300-replace-hdd.html
Mar 19, 2011 | Canon Computers & Internet
WHAT SOFTWARE CAN I INSTALL TO THE HDD OF MACHINE...
in the google write (how can i install ir3320).download and install
May 20, 2010 | Office Equipment & Supplies
Dear sir i have ir3300 cannon yesterday i switch on the machine monitor showing E602-019 HOW TO SOLVE THE PROBLEM
E602
0001 A mounting fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0002 A data read fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0003 A sector fault is detected on the HDD.
0004 A fault is detected in the read /write address for the HDD.
Main cause The wiring is faulty (short circuit, open circuit). The HDD is faulty. The
main controller PCB is faulty.
BUT FIRST: TURN OFF THE COPIER SIMOULTANIOUSLY PRESS 1 AND 9, HOLD IT, AND TURN ON THE COPIER. THIS WILL INITIALIZE THE HDD DEFRAG MODE.
TRY IT, IF NOT REPLACE HDD, AND UPGRADE SOFTWARE - NOTE: FOR UPGRADE YOU NEED THE SERVICE SUPPORT TOOL - CALL SERVICE FOR THATH
Feb 13, 2010 | Canon (6981A002AA) for imagerunner 2200,...
When i switch on the machine,error E000002 is comming
E00002 on iR3300 is problem on the heater assembly. Replace heater assembly and buy new heater assembly. Good Luck...!?
Feb 06, 2009 | Canon Office Equipment & Supplies
In Ricoh aficio 401
The SC360 is Hard disk drive error 1. This means that the machine does not detect the connection signal from the HDD.
CHECK THESE; poor connection between the HDD and the HDD controller,
the AC power connector to the HDD is disconnected,
HDD defective,
HDD controller board defective,
BICU defective.
Make sure all connections are tight and secure, make sure power is connected securely, make sure HDD ( hard drive) is not bad if so replace. If the above are fine, replace the controller board and if the problem is still there, replace the BICU board.
Nov 15, 2008 | Ricoh 6513 Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
347 people viewed this question
old marine
old marine
