Question about Ricoh Aficio 1515F Plain Paper Laser Fax
Network problem with Aficio 1515f
Hi. Can you please tell me how to connect my printer via network to my laptop running vista ultimate? The printer doesnt have a USB port,but only a network port. I bought a router and installed it and the cables from laptop to router and from router to printer. The laptop just tells me that there is limited connectivity on the local network? Any idea how to fix this please?
Sounds like you have a wireless router, but are (for some reason) plugging your laptop into it, and if it's not wireless, you should return it and get a wireless one for about the same money, that will let you use your laptop from anywhere, and the setup is often easier, as it can usually all be done via the Installation CD. You can also still plug the Aficio 1515 into the router and print wirelessly to it from your laptop, once you have it configured.
Next, the Aficio 1515 printer feature included a standard usb port, so I find this a little strange.
You can download the manuals here:
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
The 'network settings' guide will be most helpful. The two things you primarily need to be concerned with are the "IP address", and "subnet mask". Do not use "Auto", but rather set them manually, and then configure the printer driver
If you don't have a basic understanding of IP addresses, and network printing, then you'll really need some help to complete the setup
Posted on Mar 02, 2009
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
No net connectivity
If you encounter difficulties accessing computers that are visible on the network map, make sure the computer being accessed has an account with the same name/password as the system connecting to it uses to login.
To set up Network Sharing between XP and Windows Vista, please note that File and Printer Sharing is different in Windows Vista than from the setup in Windows XP.
On a computer running Windows XP, click Start, click Control Panel, and then click Network Connections.
Click Local Area Network Connection, click Properties, and then view the list of items used by the network connection.
Ensure that the Link-Layer Topology Discovery Responder check box is selected.
Jul 02, 2009 | Microsoft Windows Vista Ultimate Edition
Just bought a 1515f copier.how do l change copying preferences
Sounds like there is a preset reduction (R/E) programmed??? You can access the manuals here. The answers for your copier question should be in the "copy reference, in the "user tools" section
Manuals are all here:
....too many questions to be answered in this forum......but, are you sure that the printer feature is on the machine? Just asking, because it was not standard .
May 07, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Can't connect Xp laptop to 64Bit Vista PC to be able to print across wireless network
yes easy to fix, just share your print driver give it a share name like canonmp780 on the pc it is connected to
then get on your laptop asuming its on your wireless network and in the start bar run this command. \\ your computer name one printer is connected to \ canonmp780.
so if your computer name is windows and your printer name is canonmp780 the run command will be: \\windows\canonmp780 hope this helps and really easiest way to connect to it.
Canon tech
Apr 12, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Windows Vista Ultimate: Internet connectivity
Make sure your IPv4 settings property is set to AutoObtain the IP address under the Network properties for the wireless card
Apr 05, 2009 | Microsoft Windows Vista Ultimate Edition
Wifi
go to networks and sharing centre. There youll find an option called create a network. Select network type as 'adhoc network' and give a name. on your friends pc connect to this network
Jan 09, 2009 | Microsoft Windows Vista Ultimate Edition
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
Connectivity - Network Printer
I am having windows vista home basic in my computer. I am not able to share files to other computers connected in my network. also, I am unable to view network computers in my network. How to enable network computers visible.
Aug 03, 2008 | Microsoft Windows Vista Ultimate Edition
Ricoh 1515f
This model can be used as a printer and a scanner , but you need to add a print scan controller wich you can obtain at any ricoh otlet .
Pierre
Sep 11, 2007 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh Aficio 1515F Plain Paper Laser Fax Logo
708 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
