Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
Fuel gauge doesnt work in 73 winnebago brave d19
Fuel gauge doesnt work in 1973 winnebago brave d19
  • Anonymous May 20, 2009
    either does mine on my 73 winne
  • mike dingo Jul 24, 2012
    mine either 73 Winnebago Indian
2 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 905 Answers
SOURCE: 76 winnebago brave, not charging the batteries,
Your power converter is probably okay, since the lights are getting bright when generator runs (and probably when plugged into shore power). A coach that is as experienced as yours is probably going to have multiple wiring issues that have occurred over time. Corrosion on battery terminals is common, but so is not maintaining the batteries. Batteries are usually killed by not charging properly, discharging too deep, and not keeping them clean. The batteries can also be wore out, especially if they are more than a couple years old and spent a lot of time sitting in the back lot.
Start by looking at the cables located at the battery, as well as at the battery connection on the DC fuse block. Everything should be clean bright and shiny. If not, I would suggest loading a dremel tool with a brass brush, and clean all wires and connections individually. Make sure everything is turned off in the coach to minimize sparks. While you have the cables off, take a look at the date codes and check the water levels. Correct accordingly.
There is a possible problem that can be at the converter as well. When you supply power to the converter, a solenoid engages a switch that transfers power to the batteries, charging them. If this switch has failed, it will cause same symptoms since batteries are not being charged.
The chassis / starting battery may not be charged by the house charger at all, especially if there is a Emergency Start / E-Start / Boost button on the dash somewhere. The engine is able to charge the chassis battery and the house batteries through a big relay (looks like ford starter solenoid on coaches like yours).
If you drive down the road, and main battery doesn't charge, and house batteries don't charge, Look closely underneath your coach for a grounding problem as well as possible bad alternator. But, if your house batteries charge off the alternator, then your problem will likely lie in the switch on voltage converter. If chassis battery charges and house batteries don't, look for 30 amp fuse between house battery and relay on firewall of engine compartment.
Make sure you wear old clothing, wear eye protection, and gloves when around batteries, and also when using the dremel.
Posted on Aug 25, 2009
Fuel pump on a 1998 winnebago brave. Is it electrical or machanical?
if you don't know.... then I think you should not care..
May 14, 2017 | Cars & Trucks
What could be causing Intermittent high piched whinning sound from ford v10 engine on 1999 Winnebago Brave. Speed does not affect it and sound is causing no issues yet.
Check the tension of the fan belt as if it is to slack it will slip under load causing the noise. Tightening it solve your problem.
Oct 19, 2016 | Cars & Trucks
Speedomete, oil pressure and all other gauges on the dash of my 1999 winnebago brave just stopped working ans i can not find a problem.
It is likely the cluster is just burned out, the cluster is a computer and all info you see is computer generated from data collected from sensors on the engine and the transmission and sent to it by the engine computer. It can be tested by the dealer of the chassis your rig is built (you never say that info) on with a special scan tool.
Jun 24, 2016 | Cars & Trucks
Where are the fuses located for the 2015 Itasca Sunstar 36Y?
Winnebago RV Sales ' Itasca RV Sales ' Winnebago ...
www.lichtsinn.com/new-rvs-for-sale.aspx
Location: Main ... The All New Fuel Efficient Fuse with the Ford Transit Power Stroke Diesel! .... New 2016 Itasca Solei 36G The Forza and Solei Offer Diesel Pusher ... New 2016 Itasca Sunstar LX 27N All New Upgrades to the Vista and Sunstar with ... 2016 Brave Returns with Its New Crown as the 2015 RV of the Year Title!
Sunstar ' Specifications ' Winnebago RVs
winnebagoind.com/...a.../2015/sunstar/specificatio...
Winnebago IndustriesSunstar ... Length, 27'1", 31'3", 28'3", 31', 36'5", 35'5", 37'. Exterior Height1, 12'2", 12'2", 12'2", 12'2" ..... 2015 Winnebago Industries, Inc. All Rights Reserved.
Winnebago Industrieswinnebagoind.com/resources/manuals/Winnebago IndustriesIf you are not in a position to visit your dealer, some parts are available online at www.WinnebagoOutdoor.com. Please note that you can look up part information ...Winnebago RV Sales ' Itasca RV Sales ' Winnebago ...
Jan 01, 2016 | Itasca 2015 Sunstar 36Y
Gas gage does not work
Could be the gage or the sender unit. Have someone take the wire off the sender unit at the fuel tank and touch it to ground If the gage goes to full tank the replace the sender unit. Could also be a broken wire from the gage to sender
May 31, 2015 | Cars & Trucks
Fuel gauge not working
Hi Trev, you will have to check with your local dealers parts department for that answer. Good luck
Mar 28, 2014 | Harley Davidson Motorcycles
Need a shifter cable for a 1977 dodge winnebago brave motorhome
Usually the shifter is on the dash instead of the column so the RV companies used their own design.
I would check with the RV clubs and research the internet for salvage yards for RVs and campers. Good Sam is one that comes to mind.
You may also find something that would work at a boat dealer.
Aug 28, 2012 | Cars & Trucks
Fuel gauge doesnt work. Put in new fuel pump, no f...
Common issue on the 03-06 Rendezvous instrument clusters, usually it's caused by failing stepper motors on the cluster's circuit board and can be repaired. Check out this page for info on how to get it fixed - Rendezvous fuel gauge doesn't work
May 19, 2010 | 2004 Buick Rendezvous
2002 monte carlo fuel gauge doesnt work,pump works ok.
It is likely the fuel level sending unit. I had a customer with an 03 Monte Carlo that the pump went out and the fuel gauge hadn't worked in about a year. We replaced the fuel pump module and it took care of both problems. I believe the sending unit is available separately from the complete module.
Jan 10, 2010 | 2002 Chevrolet Monte Carlo
99 navigator gas gauge doesnt work all of a
some are on a fuse link but most of them have the fuel pump and gauge sender on the pump, it has a wire winding to work the gauge msounds like the whole fuel pump gauge sender needs to be replaced, thanks robert b.
Jun 19, 2009 | 1999 Lincoln Navigator
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
358 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
