Question about Maxtor 7Y250P0 250GB 7200RPM EIDE 8MB CACHE HARD DRIVE & WEGO NOV-AC-BA350B USB2.0 3.5" Aluminium Ex... (7Y250P0USB)
External Hard Drive Problem
I have a Freecom 250Gb External Hard Drive, ive had the hard drive for a while and had no problems, now its not showing up in either my pc or mac?The light which shows power is stil turning On.If you know anything i could do to fix this, or atleast recover my data it would be greatly appreciated
Thanks
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Freecom usb port broken away from circuit board inside enclosure
It is hard to buy replacement for the same enclosure, but there are many USB2.0/3.0 enclosures available on the market for 2.5 and 3.5 inch drives.
Make sure read reviews for issues and performance on those enclosures.
Apr 10, 2014 | Freecom Xs External Usb Hard Drive 2tb
Hi i have just tryed to connect my FREECOM 160GB EXTERNAL HARD DRIVE to my imac and nothing happens at all, the light on the front of the hard drive is on but it does not show on the imac desktop, i went...
you have to download the driver for the hard drive
go to the hard drive manufacturer web site , find the down load for you model hard drive and the imac operating system
download and run
Dec 03, 2017 | Freecom (24358) 160 GB Network Hard Drive
How do I backup files to my Freecom external hard drive XS 3.5 ?? Ive installed it but cannot workout how to use it !! there are no manuals !!
you can open Computer on your screen and then there is C: drive and Freecom labeled to it. Open first the C drive, click Ctrl + A to highlight everything. Then click Ctrl + C. Then go back to Computer and click Freecom. Then click Ctrl + V. All the files will be transferred to Freecom. Then you may proceed for your next step. That is how you back up files.
Aug 10, 2010 | Computers & Internet
Data Missing from 250GB Freecom HardDrive.
May be that is hidden..Go to the control pannel look for folder options and then in the view tab check the box show all files and then click ok.
connect it again see if are able to see your files again. if not then there are data recovery tools available on the internet.
But i think the first method will solve your problem
Jul 28, 2010 | Freecom (24358) 160 GB Network Hard Drive
Freecom Classic SL hard drive stopped working
Probable reason for failure of a disk is power, if the power is adequate may be some of its components like inductor, diodes in series with the power line are opened, check for any burn marks on the pcb
Jul 14, 2010 | Freecom Classic (22095) (22095)...
My computer has found new hardware for my freecom external storag
It should automatically allocate a drive letter to it. Go to windows explorer and hit F5 to refresh the display and you should see a new drive letter with the name of FREECOM next to it.
Oct 05, 2009 | Freecom (24358) 160 GB Network Hard Drive
I have about 39gb of family pics and music saved on my freecom 250gb external hard drive and I have had to reboot my system with a backup file using ACER e-recovery management. since then my external hard...
In the control panel, go to administrative tools, open computer management. On the left side, there will be a "Disk Management" section, use that to assign a drive letter to your hard drive.
Sep 30, 2009 | Acer Aspire™ T180 PC Desktop
My 250gb hard drive is not working
Assuming this external hard drie is powered via USB, you probably just need the drivers:
http://www.freecom.com/ecsupportdetail.asp?serie=Mobile+Hard+Drives&group=1148826&interface=1148827
Jul 01, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
