Question about Kenmore 22.0 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Refrigerator/freezer is warm, fan is running.
The refrigerator is 2 1/2 years old out of warranty. The freezer kept thawing out the food, then refreezing. I have a loud buzzing noise happening every minute or so followed by a "click noise". The noise seems to be coming from the front bottom of the refrigerator. Yesterday, I came home and everything in the freezer had thawed out, ice turned to water and the refrigerator isn't cooling. Both frig & freezer are warm not cooling. It seems the fan in the freezer is running but nothing is happening. I had to throw out all the food. Sears can't get to my house to look at it until 10/12. Please help. I'm pretty handy for a women if you guide me through the check list. Thank you! Kenmore 57542 (I guess - owners manual shows several numbers).  Purchased 1998 Freezer and fridge are warm.  I hear fan running.  I'm guessing the compressor needs to be replaced.  Let me know if this is something I can do myself.  Also, is there anything else that I should check to diagnose problem.  Thanks!
  • mike1089 Mar 02, 2009
    Kenmore side-by-side - Model number 596.57542791. Purchased in 1998
    Freezer and Fridge are not cooling. When I turn the dial for the freezer, I hear the fan running, but no click to turn on compressor. When I turn the dial for the fridge I hear no click either. Is the compressor bad or is it a switch for the compressor? Let me know if this is something I can do myself.
    I cleaned the coils and checked the fan. The fan at the back of the unit is running.
  • 547 Answers
Hi this is not some thing you can do your self the freon in lines is toxic do not attemp to fix let sears take care of it thankyou for useing fixya please rate me
Posted on Mar 02, 2009
  • albert getty
    albert getty Mar 02, 2009
    if it is all running you most likley need freon recharged you maybe able to just call local repair. thanks again for useing fixya dragonsthatk
    Sergeant:
  • 239 Answers
Your problem is the compressor on the bottom of the fridge. i used to work at sears and this is a common problem. you need to replace the compressor. the only problem is they are about 350 dollars or more depending on your model plus the labor to install it and the cost of freon if they have to refill it.
I'm sorry to here this happend.
best of luck.
I hope i helped you.
please remember to rate me.
    Genius:
  • 1,550 Answers
You may need to clean the condenser coils. This should be done about every 6 to 12 months.
Other possibilities
* Check the door gaskets for proper sealing, especially the bottom section.
* Clean the gasket surface where your door gaskets meets the metal with warm soapy water
Also you are facing this problem due to
* Incomplete defrost or not defrosting at all.
* Temperature control set to low
* Fan motor quitting
* Light in freezer stays on
* Controls
    Sergeant:
    Novelist:
  • 277 Answers
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. A ball of ice on the coils and the rest of the cooling coils are bare or only a few coils frosted a little and the rest are bare is an indication of a system problem. Example picture one, example picture two, example picture three. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
for more details on this issue click this link
http://www.applianceaid.com/frig_notcold.html
also this links
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  • Kenmore Master
  • 19,396 Answers
That is a faulty thermostate , you need to replace the thermostat.
  • Ginko
    Ginko Mar 02, 2009
    Before replacing the compressor you need to check if it is a different fault, I suggest calling a local technician or calling Kenmore http://www.kenmore.com/shc/s/nb_10154_12..." target="_blank" rel="nofollow" >Customer Care
    Scholar:
  • 165 Answers
Older refrigerators had electric heaters on the edges of the refrigerator cabinet to help prevent moisture from building up, especially in the hot/hazy weather in the summer time. These electric heaters usually had a switch where you could turn them on or off...had words like..."switch here to prevent moisture"...switch here in damp weather".... in the picture it is in the top left of the control assembly.
Then along came the energy crunch. The manufactures stopped using the electric heaters and started running a pass of the hot condenser tubing on the edges of the cabinet where the electric heaters use to be. This is often called ayoder loop tube SxS version and the yoder loop tube Top freezer version. This has now replaced the electric heaters. If you feel heat/hot around the door opening of your refrigerator you should....
clean the condenser coils as a dirty condenser can make the tubing hotter than normal
- check/clean & replace if necessary the condenser cooling fan   ( # F ) motor, if the condenser fan motor is slow or has quit the yoder loop pass will get very warm/hot to the touch
- If the condenser coils are clean and the condenser fan motor is running ok, check the fresh food and freezer section temperatures...if the refrigerator is not operating well and the temps inside are warming up, you could feel more heat/warmth than normal
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator and Freezer not cooling Maytag MFI2665XEM7
check to be sure condenser fan motor is still working bottom back of refrigerator , also is there frost at back of freezer if so you have a defrost problem,
Nov 30, 2013 | Maytag Refrigerators
LG bottom freezer not freezing food completely food starting to thaw. LG only 1 year old!!!
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 29, 2010 | LG LRDC22744 Bottom Freezer Refrigerator
FREEZER NOT FREEZING AND F RIDGE FEELING WARM
Before you throw out this refrigerator, try a few simple tests.
First, open the freezer while the compressor is running and listen for the fan running. If it is not, this could be your problem. Replacement fans can be ordered from on-line parts stores, a local appliance repair shop, even ebay.
Second, try turning off the refrigerator and letting the coils in the freezer thaw completely. Of course, move your food to a safe place for a few hours while you thaw the freezer. If you really get ambitious, remove the rear panel from the freezer and look to see if the coils are frozen. If they are, thaw them and dry the freezer compartment completely. Reassemble the freezer and restart the refrigerator.
If the problem reoccurs, you may have a problem with your defrosting circuit.
Jan 30, 2010 | Frigidaire Freezers
The freezer is warming up
If you found something lodged in the door that may have kept it open for a while, i suspect frost formed on the coils behind the panel. Frost will not let air pass through the coils to the refrigerator side. This is one of the most common problems there is. If you look through the louvers on the rear panel that is for sure your problem. It most likely just needs thawed out. After it is thawed out, your normal defrosting routine will take over again and hopefully you will be trouble free again.
May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a G.E. mod.# GSS22KGMCWW refrigerator that frosts
you have defrost problem 1 timer 2 defrost thermostart 3 heater best way call service
Apr 05, 2009 | Amana ARS2464B Side by Side Refrigerator
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Sep 29, 2007 | Refrigerators
Refrigerators Logo
61 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
