Question about Star Logic 17" LCD Monitor
I have a Star Logic 20" monitor and cannot get the resolution set higher than 800 x 600. HELP?
  • 741 Answers
You are limited to the capabilities of your video card in your computer. The monitor itself is not part of the ability to raise the resolution. Go to Display Properties under Control Panel and slide the resolution all the way to the right. If the max is 800X600 then that is the max for your video card. Buy new video card.
Rate the solution with 4 diamonds.
Posted on Mar 02, 2009
I have a star logic monitor and it is not working. When i insert the power cord a dim blue light blinks, but then when i insert the computer to monitor cable, the dim blue blinking light goes away and it...
  1. Please try by reseating the RAM modules.
  2. Please check the VGA output port is properly fixed.
  3. Reset the BIOS to its default.
  4. Check whether the monitor colour resolution is out of range
If yes, set it to default.
Please check whether is works with different computer
IF yes, Check the VGA port.
Feb 07, 2011 | Star Logic Monitor
Tip
If resolution of monitor set to higher than it limit
Hello<br /> Many times it may happen that the resolution of the monitor is set to higher than its limit causes the monitor to be in off state and thus make the system inoperable to overcome such problem you can perform some usefull tips as follows<br /> Start the system, after a few minutes just click the Right mouse button and on the keyboard press Down Arrow key for "Seven times" then press Right Arrow key one time then press Down arrow key again once. Then press Enter. The resolution should set to be 800,600 thus Starts the Monitor again to normal
on Feb 07, 2011 | Computers & Internet
Displaying "out of range" when plugged in
Hello white tiger, hi, the out of range error is usually caused by a very high resolution setup on your computer display card that windows installed (generic driver), the monitor simply cannot produce the resolution, set your resolution to a safe level like 1024 by 768, most monitors can display this resolution. The root of this error message is incorrect display driver, you need CD to install the display driver. Once installed your resolution will now be controlled to a safe settings were the monitor can display properly.
Aug 20, 2010 | Star Logic Monitor
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
My monitor say out of range and no in put siginal be for this it said DVI disconnected. I can plug it into 2 other computers and it works. HELP
This problem is the screen resolution that your computer is set at. Start the computer enter safe mode, press and hold F8 as windows starts. change the resolution right hand mouse click on desk top, click on properties, lower the screen resolution, and re start. I hope that helps.
Jul 12, 2009 | Star Logic 17" LCD Monitor
Monitor power light flashes off and on. Monitor
It could be any of the two. As a troubleshooting step, and I have seen this before, try connecting the monitor directly to the wall outlet and this being a new outlet. (sometimes a power issue)
Do you have a extra power or monitor cables to rule out a cable problem?
The VGA card could be mis-seated. Turn off the computer and re-seat the video card.
Does the monitor screen show at Bios and is the problem only in windows? (in case higher resolution settting than monitor can handle)
Jul 11, 2009 | Star Logic Monitor
Installed windows vista and now I have resolution problems
Get an application called Unknown Devices and find out what your Video Adapter is and get the appropriate drivers.
Dec 17, 2008 | Star Logic 17" LCD Monitor
17" starlogic monitor model M19BNK serial M9B49CKVoo4584
blown capacitors on the vga board or the resolution for the display adapter is set too high for the monitor reduce the resolution in safe mode and you should be ok, if not then the bad capacitors are in need of being repalced
Sep 17, 2008 | Star Logic 17" LCD Monitor
Changing Resolution
there is a chance that your computer onboard video does not support a higher setting. what operating system do you have, using onboard video or a video card would assist me in giving you advice.
Robert
Aug 27, 2008 | Star Logic 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
299 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
